08-18-2005, 05:18 | #1 (permalink) |
Freak Poster Join Date: May 2004 Age: 48
Member: 66359 Status: Offline Thanks Meter: 1 | myC5-2 unlock problem Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5251843671019 KA3,RE: 091104 1843 - Phone Imei: 354057004815579 - Hash Table : 22 00 00 - Phone Code : 0000 I had solder the testpoints an still dont have any luck with it. Could sombody please tell me what is wrong.. Thanks all... |
08-18-2005, 14:31 | #2 (permalink) |
No Life Poster Join Date: Jan 2001 Location: StarSystem
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Test last UPDATE also check www.sws-sag.com for NEW good Update if you have any problem contact me or other member by posting here for help if you get new Hash table phone , juste read flash and send it to me , BR |
08-19-2005, 07:39 | #5 (permalink) |
Member: 66359 Status: Offline Thanks Meter: 1 | I get the same thing with the new update.. it still gives me the same message.. i cant even read flash to upload.. i get the message when i tell it to read flash:writefile function failed (win error code:6).. i dont know what could be wrong now.. please help |
08-20-2005, 14:04 | #8 (permalink) |
Registered User Join Date: Apr 2004 Location: paradise Age: 45
Member: 60836 Status: Offline Thanks Meter: 4 | i have this problem too all time stop at 40% and give m this Searching Phone......Not found ! Searching Phone...Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5103024561103 JA3,VF: 310105 1030 - Phone Imei: 355740000702607 - Hash Table : 0E 83 01 - Phone Code : 00000000 for test point i think that's not the problem becous i try different connecteur and solder but same problem and if it is test point why it stop only at 40% my experciece with this box that if it is test point it can go at 70% or 80% some time |
08-21-2005, 09:56 | #13 (permalink) | |
Member: 66359 Status: Offline Thanks Meter: 1 | Quote:
I think one of my led is not working, i was wondering if the could be the cause.. i cant read flash becouse it only gives me an error message.. Could the led really make that happen ? | |
sagem myC5-2 unlock code | ftl's recovery | ARM9 BASED M62 / M62+ | 10 | 10-23-2012 21:18 |
myc5-2 tp problem | hans salim | SAGEM JTAG UNLOCKER | 3 | 05-02-2009 21:49 |
myC5-2 unlock problem | Marlon Lewis | ARM9 BASED M62 / M62+ | 1 | 08-18-2005 20:25 |
myc5-2 unlock | babbu | ARM9 BASED M62 / M62+ | 1 | 01-17-2005 14:17 |
