06-17-2005, 18:42 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: With old & new friends Age: 49
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | @@@@ Flahing n22i with redbox @@@@ This week i flashed 02 n22i with RedboxII. The flash process was not successfull at first time. I have flashed phones many times with both flmashes from RedboxII support area. Now Phones are working. But... The imei of the two n22i is now the same. It result that the original imeis of the two phones has changed and probably now they have the imei of the phone from where the flashes where readed and uploaded to suport area. In RedboxII home page we read clearly "Our softs dont change imei" Its true, there is no direct imei change function available in soft interface, but the same soft, with flash causes imei change. I hope that in future updates, this BUG will be corrected. One suggestionon : is to implement imei saving and restoring in flash process 1- Save imei and necessary data 2- Flash phone 3- Restoring imei and data saved Please, read this and post your opinion !! Best regards |
06-17-2005, 20:01 | #2 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | i falsh many nec , 22i worcked perfect the only tric is use win XP , under win98 you must try more than 20 times to have succefuly fluched , but undr winXp al worck fine |
06-17-2005, 22:39 | #3 (permalink) | |
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | Quote:
I also constat that there are less bugs with total nec commander V2.8 than V3.0. I missed in my first post another bug. After flash successfull phone works good, but when i try to enter "Security" menu item, phone restarts network searching. Whats ur opinion about imei change ? Best regards | |
06-18-2005, 15:28 | #4 (permalink) | |
No Life Poster Join Date: Jan 2001 Location: StarSystem
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Quote:
nothing about IMEI BR | |
06-18-2005, 17:41 | #5 (permalink) |
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | @ Mr Julivir Take 01 nec N22i, flash it with redboxII and flash file from ur support area then check its imei. U ll constat that the imei has changed. An probably the new imei will be : 351175/99/306556/9. After, give us ur opinion about imei ... it is a little difficult than saying "nothing about imei" I also invite all members to do this experience. I started this thread not for showing RedboxII bugs (all softs have bugs.....) but for inviting you to resove it in future updates. Best regards !!! |
06-18-2005, 19:51 | #6 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Paris, France Age: 45
Member: 45387 Status: Offline Thanks Meter: 53 | today succesfully flashed one 22i 5 times sometimes the ringtones dont work and there is no screensaver sometimes the phones dead sometimes the phones blinking but after flashing many time the phone work ok without any problém any without imei changing BR |
06-19-2005, 11:29 | #7 (permalink) | |
Did you used Rewrite eeprom option ? Best regards | |
06-19-2005, 13:26 | #8 (permalink) |
Member: 45387 Status: Offline Thanks Meter: 53 | yes N22i_Full_Flash the second flash file ''22i_complet'' dont work for me always phones dead with it but with the first it work fine and yes i used rewrite eeprom area option BR |
