04-03-2006, 00:09 | #16 (permalink) | |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | br <= The_Gorr => Quote:
04-03-2006, 08:16 | #17 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | Quote:
04-03-2006, 10:34 | #19 (permalink) | |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | If you got New Frimware version, you can unlock your phone using following steps : go to Panel "UPDATE". Choose Correct Com Port and Choose "Unlock Method 1" than Press Start. If soft not found correct data use Methode 2. br <= The_Gorr => Quote:
04-04-2006, 02:10 | #21 (permalink) |
No Life Poster Join Date: May 2003
Member: 29652 Status: Offline Thanks Meter: 43 | i have problem using last version of lg 3g 1,4b THEY DONT UNLOCK LG U8210 i was triyng so much time whit many cables lg7050 from redbox ,lg3g directly and nothing and i unlock it using other box whit lg7050 redbox cable |
04-04-2006, 02:52 | #22 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Is everything goes fine with me?? - plug lpt > plug usb > open exe. I can run the soft, all fine. But i can't see red box usb device on device manager. Should it appear? What is this usb for? Supplied Vcc to the box or else? BR Newbie on Redbox II |
04-04-2006, 08:37 | #24 (permalink) | |
for unlock or Flash you can use serial cabel or USB , support worck on manuel for explain many truc for RedBox | |
04-04-2006, 10:21 | #25 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Thankyou Mr.Hitibiti. I see now, all fine with me. ----- Phillip comander 5.5 : Philips 530.Trying to enter TAT mode always error. Progress bar stops @50%. ------- Power ON Phone...OK! TAT MODE..Error!! How to entering TAT mode easily? Open exe > press TAT mode > plug rj45 cable to box > says: "power on ok" but always stops at 50% Only with this way soft can connect to phone. Is it wrong? Regards |
04-04-2006, 11:13 | #26 (permalink) | |
if yes try to use other EXe older one and telme the result if ther is bug , it will be fixed in next update | |
04-04-2006, 12:54 | #27 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Yes.. with 4.1 can connect. But i got message : "Firmware not supported, please read flash and send........" But after that none of buton can be use. and the next message is: "communication error" BR is something wrong with the forum? i can't attach screen shot. |
04-04-2006, 13:11 | #28 (permalink) | |
04-04-2006, 22:35 | #29 (permalink) |
Member: 29652 Status: Offline Thanks Meter: 43 | and what about my post???? i have problem using last version of lg 3g 1,4b THEY DONT UNLOCK LG U8210 i was triyng so much time whit many cables lg7050 from redbox ,lg3g directly and nothing |
04-05-2006, 10:49 | #30 (permalink) | |
use last version and telm witch Lg can't be unlocked and witch version of LG and post pic to see error Exemple : ( LG 8330 V20a) Thx | |
post all setool problems here | taopheek | SETool2 | 85 | 11-13-2011 15:47 |
Report All Ust Bugs Here.... | manju | UST Pro II | 11 | 04-22-2007 14:04 |
Report All Multibox Bugs Here!!! | arsenal | Multi-Box | 0 | 04-14-2006 13:20 |
