04-26-2006, 17:35 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Problems with DeepFreeze and Redbox. But now I have problems opening the programs with the first "redbox.sws" file that I generated for the first time after installing the setup. I thawed DeepFreeze and installed again the Redbox installer and got the "redbox.sws" file again and copied to all the folders, but when I freeze again I encounter problems, and now I am unable to get any more "redbox.sws" files from the server, so I have problems when I want to run Redbox softwares, and I am using right now just the old .exes which had the "xxxxxxxxxxx.key" file, and the programs open very well for the first time that I double-click on them. Any advice |
04-26-2006, 18:17 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | Pm julvir and send him your box sn, he will reset your key from server, to be able to download a new key but you have to save your key in a secure folder (don't forget this) br <= The_Gorr => Quote:
05-01-2006, 16:51 | #3 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | I have again the same problem. Julvir resetted my key and I downloaded it again and started to test all the .EXEs and I arrived till Panasonic and then at Panasonic exes I encountered the problem again and now no one of the programs open - I always have the same "Bad Key File" message. Otherwise the older exes are all opening at the first try with the old key file. Can the problem be that I putted the new .SWS file together with the old EXEs and old KEY file? Any advice Julvir? I need to solve this problem urgently, cause it is making me mad. |
05-01-2006, 17:12 | #4 (permalink) | |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | contact me via msn i can resolve your problem br <= The_Gorr => Quote:
05-04-2006, 12:37 | #5 (permalink) | |
No Life Poster Join Date: Jan 2001 Location: StarSystem
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Quote:
After restart you normaly can restart the exe if can not , i really dont know why :-( | |
05-04-2006, 15:05 | #6 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | I have come to a conclusion that the problem does not lie on DeepFreeze, but there is a bug with Redbox softwares, cause when I received the second key, I open some programs, but when I want to open the Panasonic soft then comes the Bad Key File message. And should the key be the same as I had before, eg 162a3a445464.key? Now it has another value. And if your soft is not 100% good, then don't put restrictions on me for downloading the Key files till I resolve the problem, cause if I receive any phone that I should use Redbox I must return it. Plus many times I returned many phones that Redbox cannot unlock - sometimes new version, sometimes any bug, etc. |
05-04-2006, 15:10 | #7 (permalink) | |
only need be .sws now for can work also this problem can come from our themida packer / protector , only panasonic make you problem ? | |
05-04-2006, 15:15 | #8 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | I just opened the Alcatel 152 exe with the .SWS key? I am really surprised how it opened now? But is it normal that I don't have the old Key value in the BOX ID field? Now I have there just ACACACACACACAC |
05-04-2006, 15:43 | #10 (permalink) | |
Ok , you have juste very bad connection with the box , ACACACACAC or E2E2E2E2E2E is bad connection with box , so juste change LPT cable for see but your problem come from LPT connection | |
05-04-2006, 17:46 | #11 (permalink) | |
Member: 21296 Status: Offline Thanks Meter: 328 | But I have ACACACACAC from the begining, even when the programs open and they work with ACACACACAC present, but I have again problems after restart - they are not opening now anymore. Quote:
05-04-2006, 18:07 | #12 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | If it was a cable problem then why the old exes with the red icon open at the first time and I never in my life opened them more easy, with a single click. I had before the same problem with the those, but now I have the problem with these new ones. |
05-04-2006, 18:26 | #15 (permalink) | |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | freind please : ACACACACAC and E2E2E2E2E2E are code error and from these code we can understund the problem and determinate the solution... so if Julvir tell you that ACACACACAC or E2E2E2E2E2E means bad connection with box, so it's not mean that's a key problem br <= The_Gorr => Quote:
Problem with HWK and UFSx3 all orginal and not work what to do ?????? | wgmmmx | HWK | 5 | 04-01-2008 22:18 |
Problem With 5200 And 5300 Unlocking With Free Method | strangerboy | MT-BOX | 52 | 09-13-2007 15:35 |
Problem with SETool and IMEI with w550 | Bohosh | Sony Ericsson | 4 | 01-14-2006 10:57 |
Problem With My New Redbox....plrase Help | sofiame2006 | Redbox | 1 | 05-31-2005 17:57 |
