04-29-2006, 20:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Mouscron/ Belguim Age: 46
Member: 18703 Status: Offline Thanks Meter: 330 | redBox get bad calculation for G50 error to red and flash Alcatel and to day big surprise error to calculat G50 code after try 2 time whit the code gived by redbox calculator i try Cyber GSM v 6.1 differant code and worked code see atach im not happy for this box |
04-29-2006, 20:36 | #2 (permalink) |
No Life Poster Join Date: Apr 2000 Location: near you Age: 60
Member: 1196 Status: Offline Thanks Meter: 6 | look what you did you set G51 in REDBOX and on another picture I saw calculating for GD50 phone ,,,REDBOX is good box ,,,I think your finger work very fast ,,maybe you make a mistake ,,think one time again |
04-30-2006, 00:29 | #3 (permalink) | |
No Life Poster Join Date: Sep 2000 Location: MAROC
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | Quote:
Phone: Panasonic GD55 IMEI: 352205003156972 NCKKN: **00012*15873977# NCKKN 2: **00013*25404877# NSCKN: **00022*15473177# NSCKN 2: **00023*25600877# SPCKS: **00032*15178127# SPCKS 2: **00033*20657877# CKCCK: **00042*15692147# CKCCK 2: **00043*24672077# PCKKP: **00052*15875997# PCKKP 2: **00053*27424877# it's same as free calc, old g50 firmware have similare algo and hash like GD55, you need just select GD55 as you see in ******** calc G50/51/GD55 for newest G50 and G51 this codes will not work and you need calc with correct model selected. also what alcatel that you can't read write flash ??? if you want just increase your post go away Regards, PS: i forgot there also in redbox one soft called total panasonic commander that allow you to unlock/flash directly with cable all G5x familly Last edited by PADERF; 04-30-2006 at 00:44. | |
04-30-2006, 20:32 | #4 (permalink) | |
Member: 18703 Status: Offline Thanks Meter: 330 | Quote:
bat you panasonic cable commander give error is booting too philips 330 cant unlock LG 8210 cant unlock first correct bug for fimous model after make soft for lobaster model | |
04-30-2006, 23:18 | #5 (permalink) | |
try other forum tread for increase your post and leave this section for people how want realy support. Regards. | |
05-01-2006, 00:58 | #6 (permalink) | |
it just this what you like lising here ok no problem no bug in all your soft it fantastic | |
05-01-2006, 11:11 | #7 (permalink) |
Member: 1196 Status: Offline Thanks Meter: 6 | foufou ,what is the point of your comment here ,,you are angry ,dissapointed or frustrate ,I don't understand your statemant,but it is time to close this theme |
05-01-2006, 11:26 | #8 (permalink) |
No Life Poster Join Date: Jan 2006 Location: gsmtower.com
Member: 226755 Status: Offline Thanks Meter: 198 | WHY TO CLOSE ? WE HAVE PAIED THIS BOX AND WE WAN'T A RESULT ! THE SERVER DON'T WORK SINCE A LONG TIME FOR ME, WHY ? http://217.35.92.127/server |
@@ ADD REPAIRE " bad key" FOR REDBOX " @@@ | zine | Redbox | 7 | 08-28-2005 04:03 |
@julivir REDBOX II - Bad key file | dzunlocker | Redbox | 5 | 06-11-2005 08:17 |
E808 MOT UNLOCK WITH REDBOX VERY BAD @julvir | sunnyc | Redbox | 6 | 03-30-2005 00:04 |
Where To Get Samsung Flashfiles For Redbox | wearephones | Redbox | 7 | 06-30-2004 08:18 |
where can i get a motorola unlocking calculator for free? | llcooll | Motorola P2k | 29 | 02-17-2004 00:27 |
