sws-redbox/sag help hello every body specialy JULVIR & PADERF,im almost years unlocking im not beginner i modified any cable for unlock,now i will unlock sagem myx-5m i make solder the tp open soft ok version 1 i used before update cost i cant make update for version to for latest soft to use now again soft always searching fone not found error but i try all soft latest from support modify cable likw paderf said before cant connect to make the long story short i broke the test point solder pls help to unlock by keypad type imei is 351802002330987 model myx-5m im very desperate everything i tried but no luck until i broke the tp line pls boss julvir and boss paderf help me to solve this or give me were is another testpoit line.2nd for sws redbox2 i will unlock nec e808s before i unlock e606 thru testpoint n soft crack n univox not my redbox2 now i rely on redbox2 to unlock this unit cant connect cant unlock until again i broke also the testpoint area one also same with sag one line pls julvir and paderf can you provide me a keypad typing unlock or code to unlock this unit nec e808s i had 3g sim pls...pls..pls...help me i do everything to unlock unit i used new cdma crack soft no response scanning...pls boss help me.thanks a lot il wait for your reply and also pls pm me for that |
