09-13-2005, 21:35 | #4 (permalink) | |
No Life Poster Join Date: Sep 2000 Location: MAROC
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | Quote:
@Unlockcel post exactly what message you get when you run soft.. run update tool and try read SN if you read it correctly send your SN and we solve your problem | |
09-14-2005, 00:16 | #5 (permalink) |
Freak Poster Join Date: Jul 2003 Location: South America
Member: 33057 Status: Offline Thanks Meter: 0 | very simple. I it tapeworm kept along with many others dongles, by long time (to paderf knows because). the question is that I update for x1-2 sagem then I dust dongles and tries to update it and all worked execto very well this dongle that leaves KEY_NO_FOUND to me. thanks.. |
09-14-2005, 13:03 | #6 (permalink) |
Freak Poster Join Date: Jun 2003 Location: lahore Age: 40
Member: 31610 Status: Offline Thanks Meter: 5 | i have probelm whan i unlock phone read ok software ask check test point after update this problem come pls help me sws-sag team thanks Last edited by aligsmpak; 09-14-2005 at 15:43. |
09-14-2005, 13:12 | #7 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | Quote:
very simple my friend as you said but your english is very dificult to understand so here's simple question can you read dongle sn with update client yes or no? regards | |
09-14-2005, 15:48 | #8 (permalink) | |
Member: 33057 Status: Offline Thanks Meter: 0 | Quote:
clic in READ SN: = KEY NO FOUND!!! no read... yes.. no read!!! sorry my english is very very bad... and translater is other bad... | |
09-14-2005, 19:45 | #9 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Poland Age: 46
Member: 43823 Status: Offline Thanks Meter: 308 | - check LPT port (in BIOS set to ECP) - check LPT cable (best to change to new one for testing) - check USB power supply from computer (best way to be sure that SWS it's powered it's connect USB from active USB HUB - then you are sure that it gots stable 5V) - connect SWS and run leatest version of key update If still Key bot find only way it's contact with your resseler for change or repair |
09-14-2005, 20:38 | #10 (permalink) | |
but the problem is not that. proven I and with but of 5 dongles sws-sag and all estan ok. less this. the problem is dongle. and I believe that the unica solution is to send to sws-sag team. thanks all for you answer.. | |
09-14-2005, 22:18 | #11 (permalink) |
Freak Poster Join Date: Oct 2004 Location: South America Age: 46
Member: 86568 Status: Offline Thanks Meter: 4 | Hi he means that Doongle is not working he need know if is posible solve with some update or special software or have to resend to his reseller . he proves other doogles in same PC and others WorKs good just this one have this problem best regards juan aldo |
10-21-2005, 18:24 | #12 (permalink) | |
Freak Poster Join Date: Nov 2001 Location: SENEGAL
Member: 7335 Status: Offline Thanks Meter: 1 | key Quote:
my key make since some days "key not found " and when i try upddate it's make : KEY SN : 0123xxxx Reset Key...OK. Connecting to server... OK!!! Asking server for access...OK. Asking server for Update...OK. Updating Key Plz wait...Error!! Try Again ! taboucom B.R | |
11-25-2005, 17:09 | #14 (permalink) |
Banned Join Date: Apr 2004 Location: **NEDROMA** Age: 51
Member: 63194 Status: Offline Thanks Meter: 59 | hehehehe nice answer @Unlockcel post exactly what message you get when you run soft.. run update tool and try read SN if you read it correctly send your SN and we solve your problem hi,where we send sn ! |
my 6500c is dead, need help! | zaibitul | Nokia Base Band 5 ( BB-5 ) | 5 | 10-11-2010 15:44 |
Help Sws-Sag Is Show Key not found | bhama_shah | SwS_SaG_BoX | 4 | 03-25-2007 16:22 |
as sws redbox and sag is dead | spider-man | Redbox | 7 | 11-13-2006 20:57 |
www.sws-sag.com ......dead | .:Kuku:. | Redbox | 4 | 10-18-2005 23:14 |
SWS-SAG is not possible to update!! | mayer | Redbox | 1 | 06-21-2005 15:14 |
