09-01-2005, 07:08 | #1 (permalink) |
Junior Member Join Date: Apr 2005 Location: India !!!!!!!!!!!!!! Age: 75
Member: 134270 Status: Offline Thanks Meter: 0 | u8180 dead after unlock& damaged TP I tried u8180 with redbox for unlock,phone is dead and also i tried flash with Tp then damage TP,any method for repaire my phone with out TP or any other TP in phone.Ple help me ........ thanks ch |
09-01-2005, 08:05 | #2 (permalink) |
No Life Poster Join Date: Mar 2004 Location: romania Age: 42
Member: 57035 Status: Offline Thanks Meter: 70 | you must repair the test point first ... take a magnifing glass and look there are two little wires that are comint to that test point abnd are united by that test point .. if the test point is broken you must remake the lilnk there between those 2 wires ... after that flash the phone and unlock it ! good luck ! |
09-02-2005, 05:10 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Cambodia
Member: 59030 Status: Offline Thanks Meter: 165 | i got similar situation with few of these phones..if you press unlock phone.. the phone will be dead..you have to make testpoint as instructed by redbox..and then flash the phone with FULL flash file by select Personal flasher tap, check Full flash and select the repair full flash file from Redbox. This file is only single file, not four files...after flash the phone will not turn on..use same testpoint and press unlock..phone should be OK after that.. Only one phone that I unlocked this way and it's now dead and I DO need help also..after trying to full flash it, the software fully erase the flash but did not write flash..now the phone will not finish reading and let me do anything..if anyone has solution, please help |
LG u8180 Dead after Full Flashing. Plz Help!! | citifone | LG | 12 | 11-06-2008 12:44 |
LG u8180 Dead after Using New 3g Soft. Pls Help | citifone | Redbox | 22 | 11-24-2005 15:49 |
LG u8180 Dead After Flash with Redbox,Plz Help | citifone | Redbox | 0 | 08-30-2005 06:35 |
Samsung X460 dead after water damage | duha2 | Samsung Hardware Repair | 3 | 08-16-2005 08:38 |
LG U8180 dead after TP | Gsm-Unlock | LG | 13 | 06-19-2005 07:39 |
