05-10-2005, 17:16 | #1 (permalink) | |
Freak Poster Join Date: Jul 2003 Location: South America
Member: 33057 Status: Offline Thanks Meter: 0 | sws-sag no support myV-55 Hasp 22? Quote:
fono is the VODAFONE (EU) | |
05-27-2005, 16:54 | #5 (permalink) |
Freak Poster Join Date: Dec 2001 Location: UK
Member: 7894 Status: Offline Thanks Meter: 7 | My-V55 Hash Table 22 Same problem Code: Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5270139845160 KB3,ME: 280904 1607 - Phone Imei: 353415006756210 - Hash Table : 22 - Phone Code : 00000000 Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5270139845160 KB3,ME: 280904 1607 - Phone Imei: 353415006756210 - Hash Table : 22 - Phone Code : 00000000 Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5270139845160 KB3,ME: 280904 1607 - Phone Imei: 353415006756210 - Hash Table : 22 - Phone Code : 00000000 Test points: OK and Soldered Battery: Powered phone Via Bench Power Supply SW: sagem_update8.exe and dongle updated on line Any more ideas ? |
05-27-2005, 17:11 | #6 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Turkey Age: 43
Member: 2088 Status: Offline Sonork: 100.1630154 Thanks Meter: 57 | hash 22 is a very well known hash and is old .. 1st- try cleaning solderings and solder test points again 2nd - try on another pc 3rd - pray a little Regards |
05-27-2005, 19:13 | #9 (permalink) | |
No Life Poster Join Date: May 2003
Member: 30098 Status: Offline Thanks Meter: 29 | Quote:
Basically its a connection problem you have. | |
06-26-2005, 08:02 | #10 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Sahiwal Punjab , Pakistan
Member: 123133 Status: Offline Sonork: 100.999 Thanks Meter: 911 | same problem on myx5-2 hash 22 PS : Read Tutorial before using Flash tab. Searching Phone..Found. Reading Phone Info : Error! - Phone Frimware : 5092341605510 KB3,MJ: 051004 1509 - Phone Imei: 353056008093143 Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5092341605510 KB3,MJ: 051004 1509 - Phone Imei: 353056008093143 - Hash Table : 22 - Phone Code : 00000000 Br Kuku |
07-18-2005, 09:36 | #12 (permalink) |
Freak Poster Join Date: May 2004 Age: 44
Member: 65965 Status: Offline Thanks Meter: 3 | i have same problem . bad connection check your test point. .... test point 100% ok on my x5-2 and on x55 . some solution ? ai have tryed to change voltage in box from 4 to 8 volts . same problem .... |
Sws Support MyV-55 Flash Or No | Faster Update | Redbox | 2 | 02-01-2006 11:08 |
plase myv 56 Hash Table : 84 08 01 sws sag update | turkgsmteam | Redbox | 1 | 09-20-2005 13:38 |
Sws-sag not support myx5-2 HASP 62? | Unlockcel | Redbox | 1 | 04-28-2005 13:03 |
Poll: Sws-sag to support flashing sagem phones | Murat Bekar | Redbox | 21 | 04-17-2005 18:36 |
SWS-Sag update support C3, C3b, X55, SG-321.... | Multi-COM | ARM9 BASED M62 / M62+ | 10 | 04-10-2005 12:20 |
