05-15-2006, 15:01 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: India Age: 43
Member: 50805 Status: Offline Thanks Meter: 101 | SWS-SAG Key Not Found Perfect Solution... for sws-sag user who are facing Key Not Found..! problem...i've repair with this solution many boxex..also before this solution..i've try many but not get sucess..this work 100%..tested on many boxex.. Step:-1 Just Open ur Box.. Step:-2 Find 4 MHZ crystal near USB Connector.. Step:-3 First resolder the 4 MHZ crystal..and chk again if still Key Not Found..! then step 4 Step:-4 Replace this 4 MHZ crystal with newone ..(not sure but sometime bad connection also cause by this..if i m not wrong.) See this Image's next time i update this with new clear images best regards.. Last edited by muksforu; 05-15-2006 at 15:38. |
05-15-2006, 16:51 | #3 (permalink) |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | @ The_gore. yes you are right, but how many cell phone repairer can't find a crystel with it's velue on small pcb with big parts, then cell phone pcb. ? @ muksforu, just want to say . this is realy use ful for all who have this error Key Not Found..! wbr |
05-19-2006, 19:19 | #4 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
this solution don't work, i have changed two quartz. | |
05-20-2006, 07:44 | #5 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Chisinau, Moldova
Member: 201953 Status: Offline Thanks Meter: 3 | i have same problem key not found! i change the crystal but same key not found. help me please . when i try to update key i see updating key ERROR,try again |
05-23-2006, 09:19 | #8 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Poland Age: 46
Member: 43823 Status: Offline Thanks Meter: 308 | there are two solutions: 1) Easy: resend back to you resseler for chaneg Box 2) Complicated: fidn where problem are..if nothign helps so Atmega it's death and must send back to resseler |
05-23-2006, 14:24 | #10 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | yes, i got this problem with two box, after changing it, the 2nd dead too, in some days, very bad box, and this solution of sending back to reseler is stupid. |
11-09-2006, 19:37 | #11 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: india Age: 40
Member: 332894 Status: Offline Thanks Meter: 78 | Quote:
sws-sag key not found 100% soulution her | NSM TECHNOLOGIES | SwS_SaG_BoX | 24 | 11-25-2006 17:45 |
SWS-SAG: key not found | abel peter | Redbox | 9 | 08-19-2005 17:58 |
Sws-sag -key not found!!! | chinex14 | Redbox | 0 | 07-22-2005 19:58 |
sws-sag key not found | ACE_UK | Redbox | 18 | 06-23-2005 14:17 |
- SwS-SAG-BoX - KEY NOT FOUND - SOLVED !! ENJOY !!! | julvir | ARM9 BASED M62 / M62+ | 13 | 05-24-2005 18:04 |
