10-18-2006, 06:40 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: E G Y P T Age: 40
Member: 70053 Status: Offline Thanks Meter: 85 | mr.julvir what is this Searching Phone...Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Firmware : 5001508923416 JA3,VI: 080905 1015 - Phone Imei: 355980001426133 - Hash Table : 60 14 01 - Phone Code : 0000 what is proplem |
10-18-2006, 07:23 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | Bro It Is Already Talked About This Topic Make Ground To Testpoint No.7 Pin And Solder To Phone Ground It Is The Last And Working Solution |
10-23-2006, 00:17 | #5 (permalink) |
Member: 70053 Status: Offline Thanks Meter: 85 | Searching Phone...Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Firmware : 5357084602111 JA3,YD: 040106 1621 - Phone Imei: 358190007314260 - Hash Table : 31 04 01 - Phone Code : 0000 Searching Phone...Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Firmware : 5357084602111 JA3,YD: 040106 1621 - Phone Imei: 358190007314260 - Hash Table : 31 04 01 - Phone Code : 0000 Searching Phone...Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Firmware : 5357084602111 JA3,YD: 040106 1621 - Phone Imei: 358190007314260 - Hash Table : 31 04 01 - Phone Code : 0000 Searching Phone...Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Firmware : 5357084602111 JA3,YD: 040106 1621 - Phone Imei: 358190007314260 - Hash Table : 31 04 01 - Phone Code : 0000 |
10-25-2006, 09:36 | #12 (permalink) |
Member: 70053 Status: Offline Thanks Meter: 85 | 1-i checked my cable it is ok ==========vishnugsm may be ur cable prob..use another 1 2-and make pin 8 tp gnd========touftouf78 no friend ,make pin 8 tp to ground pcb and all is ok 3-and TP ok ======== hitibiti verify your test point freind 4-also shorting all cable when i read phone i have BAD CONNECTION CHECK YOUR TEST POINT in 40% not 20% |
10-25-2006, 09:56 | #14 (permalink) | |
Member: 70053 Status: Offline Thanks Meter: 85 | Quote:
i think i cannot unlock with sws thanks Last edited by hanen; 10-25-2006 at 12:12. | |
Mr odia what is this update | abdouunlok | HWK | 8 | 03-27-2008 20:02 |
mr.LEAD what is this error cru9.66 by w810i | .:T0PNET_GSM:. | Cruiser Suite | 3 | 05-20-2006 08:09 |
Mr Gobi what is this erreur??? | colin42100 | VygisToolbox | 4 | 04-18-2005 11:01 |
