Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SwS Team Products > SwS_SaG_BoX
Old 05-15-2006, 15:01   #1 (permalink)
muksforu's Avatar
Member: 50805
Thanks Meter: 101
Arrow SWS-SAG Key Not Found Perfect Solution...
Hi..
for sws-sag user who are facing Key Not Found..! problem...i've repair with this solution many boxex..also before this solution..i've try many but not get sucess..this work 100%..tested on many boxex..
Step:-1 Just Open ur Box..
Step:-2 Find 4 MHZ crystal near USB Connector..
Step:-3 First resolder the 4 MHZ crystal..and chk again if still Key Not
Found..! then step 4
Step:-4 Replace this 4 MHZ crystal with newone ..(not sure but sometime
bad connection also cause by this..if i m not wrong.)
See this Image's next time i update this with new clear images
best regards..
Old 05-15-2006, 16:24   #2 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
good work freind, need more good picture
u can use scanner to take ur pic
br
<= The_Gorr =>
Old 05-15-2006, 16:51   #3 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
@ The_gore.
yes you are right, but how many cell phone repairer can't find a crystel with it's velue on small pcb with big parts, then cell phone pcb. ?
@ muksforu,
just want to say . this is realy use ful for all who have this error Key Not Found..!
wbr
Old 05-19-2006, 19:19   #4 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
Originally Posted by muksforu
Hi..
best regards..
posted and discuted before https://forum.gsmhosting.com/vbb/f381/sws-sag-key-not-found-100-soulution-her-274500/
this solution don't work, i have changed two quartz.
Old 05-20-2006, 07:44   #5 (permalink)
Member: 201953
Thanks Meter: 3
i have same problem key not found! i change the crystal but same key not found. help me please . when i try to update key i see updating key ERROR,try again
Old 05-22-2006, 09:13   #6 (permalink)
Multi-COM's Avatar
Member: 43823
Thanks Meter: 308
quartz are not always solution for repair this
Old 05-22-2006, 13:25   #7 (permalink)
Member: 201953
Thanks Meter: 3
where a solution please help!!!
Old 05-23-2006, 09:19   #8 (permalink)
Multi-COM's Avatar
Member: 43823
Thanks Meter: 308
there are two solutions:
1) Easy: resend back to you resseler for chaneg Box
2) Complicated: fidn where problem are..if nothign helps so Atmega it's death and must send back to resseler
Old 05-23-2006, 09:29   #9 (permalink)
GAZZUZZ's Avatar
Member: 205128
Thanks Meter: 18
Sws Sag Bad Box Never Buy It As Many Times As U Can Get Replacement As Many Times It Will Get Bad!!!! Dont Delete My Post!!!!
Old 05-23-2006, 14:24   #10 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
yes, i got this problem with two box, after changing it, the 2nd dead too, in some days, very bad box, and this solution of sending back to reseler is stupid.
Old 11-09-2006, 19:37   #11 (permalink)
vishnugsm's Avatar
Member: 332894
Thanks Meter: 78
Originally Posted by muksforu View Post
Hi..
best regards..
u r great man thanku very much my box ok.............
sws-sag key not found 100% soulution her NSM TECHNOLOGIES SwS_SaG_BoX 24 11-25-2006 17:45
SWS-SAG: key not found abel peter Redbox 9 08-19-2005 17:58
Sws-sag -key not found!!! chinex14 Redbox 0 07-22-2005 19:58
sws-sag key not found ACE_UK Redbox 18 06-23-2005 14:17
- SwS-SAG-BoX - KEY NOT FOUND - SOLVED !! ENJOY !!! julvir ARM9 BASED M62 / M62+ 13 05-24-2005 18:04
Page generated in 0.22988 seconds with 10 queries
