Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > JAF Xtras
Old 06-23-2006, 10:33   #16 (permalink)
J.A.F. Philips's Avatar
Member: 291972
Thanks Meter: 16
Originally Posted by microera
I readed flash BIN file 855 with REDBOX:
http://rapidshare.de/files/23756654/...FLASH.zip.html
but:
whichever SW I use only work on XP with AMD Athlon 1GHz!
Why?
Not work on XP (Pentium 4) and not work on Win98 1GHz Celeron!!
Hi,
JAF Philips Software works on any platform but you must be carefull with the P-KEY drivers instalation. Under Win9x may have some problems since Microsoft doesn't support since long time ago the driver productions under that OS.
Also for Intel P4 Cpu's take care to install all the latest drivers for chipsets, because they have problems with the Hyper Threading technology. This affects mainly the wrapper protections when mixed with memory invasive scanners, like active antiviruses or some certain firewals with adware-spyware removers.
Still, you must not ecounter any problem with the JAF Philips software if used properly on ANY system. It was tested comprehesive on every operating systems and hardware configurations.
Regards
J.A.F. Philips
Old 06-23-2006, 16:53   #17 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Originally Posted by J.A.F. Philips
Hi,
OH series(OT155,OT156,OT355) from Alcatel use the same cable as the old 530/535 Philips phones.
The only trick you have to remember is that not all the phones connect just with a swift push of the power key.
For some of them you have to keep the power on key for a few seconds (1-2 sec) when you see the progress bar moving, take your finger off the button.
Regards
J.A.F. Philips
OK thanks for the info will try and post results here.
Old 06-23-2006, 19:49   #18 (permalink)
Member: 87533
Thanks Meter: 3
Hi,
RedBox cables are compatible, the JAF emulator i will test tomorrow.
Regards
J.A.F. Philips
And? Have you tested it?
Old 06-29-2006, 16:33   #19 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
If someone needs I can upload flash files for OH1
Old 10-02-2010, 10:25   #20 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
Yes. i need it. I have dead one.
Rm-237 3110c unlocked by jaf bb5king by cinek. Imran Bhatti BB5KING 0 02-18-2009 16:16
how to unlock by cable Philips Genie DB2000? Motoroller Philips 6 07-23-2005 19:30
Page generated in 0.31812 seconds with 8 queries
