06-19-2006, 14:42 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: www.microera.si
Member: 4923 Status: Offline Thanks Meter: 74 | 855 unlock by JAF Philips ------------------------------ Power ON Phone Conecting and then 3% accured and then: Comunication error Comunication Error ------------------------------ I use cable of redbox GS-AT106 PAN G50(B) and redbox as communication port! (COM1) ??????? p.s. maybe cable problem? |
06-19-2006, 18:38 | #4 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Poland/Germany Age: 42
Member: 87533 Status: Offline Thanks Meter: 3 | Quote:
06-19-2006, 19:59 | #5 (permalink) |
Product Supporter Join Date: Jun 2006
Member: 291972 Status: Offline Thanks Meter: 16 | Hi, software there is already compatible with all USB2serial cables on the market. Install the drivers, plug the cable, go in Control Panel->System->Hardware->Device Manager->Ports(COM & LPT), doulbe click on it, go on Port Settings->Advanced and change it on any port you want in 1-4 range. Replug the cable, go on Setup tab in software, shoose your port - all set. As i said before, the jack cable sold by all the chinese manufacturers are not good, you have to be carefull how much you plug it inside (must not be plugged full). To change this situation, ask someone to build a cable or build yourself, from Samsung handsfree, or 855 extra accesory TV converter cable, or old 530/350 external camera. Just take the conector. That one is PERFECT, you will never have problem with any jack conected philips again. Regards J.A.F. Philips |
06-21-2006, 19:10 | #6 (permalink) |
Member: 4923 Status: Offline Thanks Meter: 74 | I try with good cable (and JAF Philips 2.86beta) and get: ________________________________ Power ON Phone Conecting Version: 02160009 Type: CT8558 Unsuported version ________________________________ is possible to unlock? |
06-21-2006, 19:55 | #8 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | Quote:
please read the flash, upload it on www.rapidshare.de and pm me the link with the flash file. 10x in advance br | |
06-21-2006, 21:03 | #9 (permalink) | |
06-21-2006, 22:10 | #10 (permalink) | |
Member: 291972 Status: Offline Thanks Meter: 16 | Quote:
of course is possible to unlock but after update, this is a new version. Please read full flash and send it to me by using the Uploaf Flash button from Extended Features. Regards J.A.F. Philips | |
06-22-2006, 06:39 | #12 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Azerbaijan Age: 38
Member: 68498 Status: Offline Thanks Meter: 152 | For Alcatel OT155(OH1) which cable do we have to use I can read unsupported version and send to you.I have tried many unibox cables they don't work at all |
06-22-2006, 07:49 | #13 (permalink) |
Member: 4923 Status: Offline Thanks Meter: 74 | I readed flash BIN file 855 with REDBOX: http://rapidshare.de/files/23756654/...FLASH.zip.html but: whichever SW I use only work on XP with AMD Athlon 1GHz! Why? Not work on XP (Pentium 4) and not work on Win98 1GHz Celeron!! Last edited by microera; 06-22-2006 at 10:50. |
06-23-2006, 07:07 | #14 (permalink) | |
Member: 68498 Status: Offline Thanks Meter: 152 | Quote:
06-23-2006, 09:28 | #15 (permalink) | |
OH series(OT155,OT156,OT355) from Alcatel use the same cable as the old 530/535 Philips phones. The only trick you have to remember is that not all the phones connect just with a swift push of the power key. For some of them you have to keep the power on key for a few seconds (1-2 sec) when you see the progress bar moving, take your finger off the button. Regards J.A.F. Philips | |
Rm-237 3110c unlocked by jaf bb5king by cinek. | Imran Bhatti | BB5KING | 0 | 02-18-2009 16:16 |
how to unlock by cable Philips Genie DB2000? | Motoroller | Philips | 6 | 07-23-2005 18:30 |
