Dead 8180... Pls Help I ve 1 8330 and 1 8180 but am trying flashing 8180 and i get this error, pls what do i need to do? Test point is well connected flashed with " USE EPI" i get this Press Power On shortly ! Phone Detected ! Chip ID: 71000301 Loading ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Flash ID: 8900 Settings Done ! Certificate sent ... HACK3R2K.COM GSM DEVELOPEMENT Settings made ... CID: 17 IMEI: 35554900151274-5 Switching to USB ... Error ... ! with " USE EPI" unchecked I get Press Power On shortly ! Phone Detected ! Chip ID: 71000301 Loading ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Flash ID: 8900 Settings Done ! Certificate sent ... HACK3R2K.COM GSM DEVELOPEMENT Settings made ... CID: 17 IMEI: 35554900151274-5 CSW BLOCKS: 0028 drive_Rec.csw ... ERROR CSW BLOCKS: 0040 drive_media.csw ... ERROR CSW BLOCKS: 00A8 drive_c_U8180_V10a_IT_20050317.csw ... ERROR CSW BLOCKS: 01E8 U8138_FileSystem_IT_U8180_V10a_IT_20050317.csw ... ERROR READY. then when tried again i get this Press Power On shortly ! Phone Detected ! Chip ID: 71000301 Error ... ! N:B what is happening pls help is needed Regards |
was able to flash 1 file into phone the others give errors Press Power On shortly ! Phone Detected ! Chip ID: 71000301 Loading ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Flash ID: 8900 Settings Done ! Certificate sent ... HACK3R2K.COM GSM DEVELOPEMENT Settings made ... CID: 17 IMEI: 35554900151274-5 CSW BLOCKS: 01E8 U8138_FileSystem_IT_U8180_V10a_IT_20050317.csw ... OK CSW BLOCKS: 00D4 U8138_phone_wcdma_4mbram_U8180_V10a_IT_20050317.cs w ... ERROR CSW BLOCKS: 00A8 drive_c_U8180_V10a_IT_20050317.csw ... ERROR CSW BLOCKS: 0040 drive_media.csw ... ERROR CSW BLOCKS: 0028 drive_Rec.csw ... ERROR what should i do? |
8180 has damadged certificate. Someone tried to flash inside 8130 conversion files. If flashing dont go fine using 8180 original firmware and TP then theres nothing u can do. Br;) |
hmmmnnnn thanx fren, it was brought to me dead (B I D) so was just trying to revive it. regards |
Br;) |
