08-19-2006, 11:14 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Inside Blackberry
Member: 288462 Status: Offline Thanks Meter: 87 | NKClip Support from Furious Team? Regards GFI |
08-19-2006, 12:47 | #2 (permalink) |
Freak Poster Join Date: May 2006
Member: 275159 Status: Offline Thanks Meter: 7 | Updating NKLip ... First make shure power adaptor is ok ... about 9V Second check update cable ... I have find out that some update cables are not ok. You can find update cable schematics + update software here .... http://www.gsmnews.net/nklip/update.rar To update you need standard interface ( like UNIBOX, FOURIOUS, INFINITY, POLAR etc... try to find one of these ... ) This is 100% correct: 1. Start Update software 2. Select appropriate COM Port 3. Press the clip button and keep pressing 3. Put update cable intro CLIP and into interface ( keep pressing the button ) 4. Put power to the clip ( keep pressing button ) ( DCT3 and DCT4 leds must be inactive if all is ok if not try again from step 3 after you remove power and update cable...) 5. Press update in Update Software ( after you select correct update pack ) 6. Wait until update begins (1-5 seconds) 7. Release button ... |
08-20-2006, 19:39 | #3 (permalink) |
Member: 288462 Status: Offline Thanks Meter: 87 | I have download the update from the link which u gave me and follow the steps below the result is still the same. I use JAF Port Emulator as I know have this with me now. Below is the result of what happened. If there is anything wrong with the steps do let me know. Thank you. 1. Start Update software Done 2. Select appropriate COM Port Done Selected ELTIMA Virtual Serial Port (COM1) 3. Press the clip button and keep pressing Done I just press and hold it there. 3. Put update cable intro CLIP and into interface ( keep pressing the button ) Done I never release the button n plug in the update cable. The busy and ok light LED are lighted up only. 4. Put power to the clip ( keep pressing button ) ( DCT3 and DCT4 leds must be inactive if all is ok if not try again from step 3 after you remove power and update cable...) Done Still pressing the button then plug in the power and still the busy and ok LED is lighted up. 5. Press update in Update Software ( after you select correct update pack ) Done Still pressing onto the unlock button I selected pack 1-4 none of them can work. 6. Wait until update begins (1-5 seconds) Done still pressing onto the button but it display transfering but later end up with failed target is not responding. 7. Release button ...[/quote] |
08-22-2006, 17:06 | #4 (permalink) |
Member: 275159 Status: Offline Thanks Meter: 7 | ... Please try to use another interface like normal USB BOX or even better ... normal COM Port Box ... Also you can try to use normal 9V battery to power the clips and if this dosen't work ... try to use 12 V power supply. + is in the center of connector.. I have never experienced like this transferring ... and after that fail... If this dosen't work please try to replace the clip ... or if you want i will try to guide you to make some modifications... :-) |
08-26-2006, 17:14 | #6 (permalink) |
Member: 288462 Status: Offline Thanks Meter: 87 | Thank bro my reseller tried using universal box and uni box as well but still cant update it. Its the second clip which I have exchange from him. I try using 9V and 12V still the same. I am just a reseller for unlocking stuffs and I am not good in electronic mod. I have ask the furious team people to help me out already see if its workable. Will update you. Thank you. Regards GFI |
08-30-2006, 07:04 | #7 (permalink) |
Member: 275159 Status: Offline Thanks Meter: 7 | one more thing ... please post here a list with all com ports installed in your computer as you see them in control panel ... and as you see them in update program(in the same order) ... |
08-30-2006, 07:25 | #8 (permalink) |
Member: 288462 Status: Offline Thanks Meter: 87 | I am using laptop. When I use JAF port Emulator on the device manager it doesnt display anything. But on the USB controllers it only display JAF flasher interface. On the update program of the NKClip it display ELTIMA Virtual Serial Port (COM1) and I am using tat to do the update but it failed. I tried with UFS-3 Port Emulator also the same results |
01-14-2007, 22:13 | #9 (permalink) |
Registered User Join Date: Sep 2005 Location: Chicago Age: 42
Member: 185300 Status: Offline Thanks Meter: 0 | Hi GFI, I just purchased the NKlip my self. It came with the update cable. I followed the steps mentioned above and I have the same results like you've described. Currently I can only unlock Nokia phones with this NKlip. I would like to get it updated so it can also unlock KG800. Do you have any luck updating the NKlip since last post? Any help is greatly appreciated. |
01-15-2007, 00:35 | #10 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
You can ask for support here http://www.gsm-forum.eu/forumdisplay.php?f=38 Br | |
03-13-2007, 09:23 | #11 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: Planet Earth Age: 67
Member: 54300 Status: Offline Thanks Meter: 20 | Quote:
Nothing more to say. Computs | |
03-13-2007, 09:26 | #12 (permalink) | |
Did you use power supply on Universal box or not coz i don't give same results with or without power supply. Try on universal box v2.00 and redbox + same results no upgrade. Computs | |
No Support From FuriouS TeaM [SOLVING] | arifdreamworld | FuriousGold | 4 | 06-18-2009 07:15 |
no reply from furious team | kashif12 | FuriouS II | 0 | 03-20-2005 20:49 |
Best Wishes from Furious Team for 2005 !! | FuriouS TeaM | FuriouS II | 22 | 01-04-2005 13:21 |
No Support From Furious Team | hiteshhitesh | FuriouS II | 0 | 12-20-2004 14:38 |
what is this still no response from FURIOUS TEAM | hiteshhitesh | FuriouS II | 0 | 12-20-2004 14:13 |
