01-30-2006, 22:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 48
Member: 107916 Status: Offline Thanks Meter: 30 | nec 338 flash failed now just hang NEC when power one i try to unlock nec 338 ( V01.04)with furious when try to unlock phone after loading boot and putting imei i have imei failed and at end phone is did not unlock then i try to flash phone . after flash phone it just hang NEC what can i doing now please leroi |
01-31-2006, 02:04 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Br | |
01-31-2006, 07:17 | #3 (permalink) |
Freak Poster Join Date: Jun 2005 Location: india Age: 42
Member: 152585 Status: Offline Thanks Meter: 6 | u r fls file is fully completed if it hang on nec u have just unlock it if cant unlock please contact me [email protected] i will give idea what to do |
01-31-2006, 11:08 | #4 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Milano, Italy Age: 37
Member: 62336 Status: Offline Thanks Meter: 115 | First of all: Flash the phone with downgrader 04to03 With serial cable repair the freezed phone and after this rewrite the imei. Phone unlocked. BR |
01-31-2006, 15:10 | #5 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Bangladesh
Member: 37349 Status: Offline Sonork: 100.1613413 Thanks Meter: 362 | Quote:
yes,solution works 100%. proxy_gsm | |
01-31-2006, 20:59 | #6 (permalink) | |
Member: 107916 Status: Offline Thanks Meter: 30 | Quote:
thanks for your help i saw my error i flash the phone without battery using usb cable i will flash it using serial cable and i will let you know . thanks for your help br leroi | |
01-31-2006, 21:38 | #7 (permalink) | |
Br | |
02-02-2006, 00:31 | #8 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: London Age: 41
Member: 123471 Status: Offline Thanks Meter: 0 | Quote:
p/s : i used usb cable to downgrade and tried to use a serial com 1 cable to rebuild imei..but don't seems to be work in this way.. BR | |
02-02-2006, 19:11 | #9 (permalink) | |
Br | |
02-02-2006, 19:23 | #10 (permalink) |
Banned Join Date: Jan 2004 Age: 32
Member: 50389 Status: Offline Thanks Meter: 36 | just downgrade it to 03 and remember it only 30% and suddenly to 100% dont wori unplucg d cable from the fone then plug and use crassy nec v2.0 select model and click full imei repair make sure u write in the correct imei from the back of the fone use ur usb cable br |
02-03-2006, 18:27 | #11 (permalink) | |
BR | |
02-04-2006, 00:16 | #12 (permalink) |
No Life Poster Join Date: Dec 2001
Member: 8102 Status: Offline Thanks Meter: 118 | This is how I unlcok v04 - Use Furious to downgrade the sw from v04 to v03 - should take about 20 mins - via usb cable - turn the fone on and phone should hang - Then use NEC Crassy to repair IMEI and thats it phone unlocked (phone must be off and then when repair imei button pressed press power button |
KG220:I made direct unlock with EUB & now just show logo & power-off | beneto | Easy-Unlocker | 4 | 08-08-2008 20:22 |
KG220:I made direct unlock with Easy-Unlocker & now just shows logo & power-off..?? | beneto | LG | 2 | 06-20-2008 18:15 |
Flash failed Now V3 Wont Power Up | mbcommunication | Smart-Clip | 8 | 04-11-2006 12:50 |
nec 338 no menu after clip unlock ver 3 ??? any one got qure | trevor | NEC | 6 | 08-01-2005 14:07 |
nec 338 flashing | paklink | NEC | 0 | 03-03-2005 06:27 |
