Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > FuriouS II
Old 11-24-2004, 18:17   #1 (permalink)
crysst's Avatar
Member: 48215
Gx25 can be unlocked by furious like gx15
I just unlocked one gx25 using furious, gx15 usb drives and usb cable for nec N8.
Regards
The Following User Says Thank You to crysst For This Useful Post:
Old 11-24-2004, 21:35   #2 (permalink)
Member: 93220
gx25
did u use the same procedure as gx 15 unlock ?
Old 11-25-2004, 08:49   #3 (permalink)
crysst's Avatar
Member: 48215
Yes, the same procedure: enter test mode **** then press 1 then 66 or 99 I dont remember the press............
Old 11-25-2004, 10:22   #4 (permalink)
Member: 8262
How to unlock GX30? It is running 100% but phone not in test mode.
Old 11-29-2004, 01:26   #5 (permalink)
huricane's Avatar
Member: 33843
how about tm150?can furious do this too??
Old 12-02-2004, 20:27   #6 (permalink)
GoGy's Avatar
Member: 69725
I have one gx25... what is procedure to unlock it as gx15 ?
thanks
Old 12-02-2004, 20:45   #7 (permalink)
crysst's Avatar
Member: 48215
easy
Conect you gx25 like gx 15.
select right com port and press unlock.
to the screen will see xxxxxx
then falow the instruction from the program: press 1 then...................
Old 12-02-2004, 21:03   #8 (permalink)
GoGy's Avatar
Member: 69725
phone powered ON or OFF?
Anything... I haven't unlocked any gx15 yet... so I don't know the procedure...
I got error on 3%
Old 12-02-2004, 21:57   #9 (permalink)
crysst's Avatar
Member: 48215
if you got error to 3% then the conection is not good.
First you must have instaled gx15 usb drivers
Second you must use a usb cable for gx15
Third select right com port where usb emulate (for me was com 6) and the battery must be full.
Regards
Old 12-02-2004, 22:19   #10 (permalink)
GoGy's Avatar
Member: 69725
Where to set or check this USB emulate
I have instaled drivers... but how can I do all this by USB cable if we talk about furious which support only COM port connection?
Is that emulate respoinsible for this?
Sorry if I don't know something as you know but I am trying and no success
thanks for your help anyway
Old 12-02-2004, 22:23   #11 (permalink)
crysst's Avatar
Member: 48215
Sincerly, I dont know how see what port the driver emulated but you can try all the ports you have in program...... cannot be more.....take 1 and then 2 and......until the phone will be conected.
Old 12-02-2004, 22:24   #12 (permalink)
GoGy's Avatar
Member: 69725
thanks a lot...
only one more confirmation please...
we both are talking about furious? or some free soft?
Old 12-02-2004, 22:25   #13 (permalink)
moni108's Avatar
Member: 26440
1. install gx 15 driver
2. connect the nec usb cable 2 the gx15 and all the driver should install.
3. when it says the hardware is correctly installed open under system, device mange and check which com-port is assigned 2 the gx15.
4. run the sharp gx15 unlocker and match the com-port from the drop down list.
5. follow instructions.
Old 12-02-2004, 22:26   #14 (permalink)
GoGy's Avatar
Member: 69725
phone turned ON or OFF?
Old 12-02-2004, 22:29   #15 (permalink)
moni108's Avatar
Member: 26440
1. nstall only gx15 driver, connect the usb (nec cable which comes with furious) 2 the gx-15 and power on the fone.cant remember exactly but i think fone was on when i press unlock .
lg u310 can be unlocked by furious gold aleem26 LG 6 07-09-2011 15:20
lg u400 can be unlocked with furious?(Solved) GSMman187 FuriouS TeaM Products 5 10-21-2009 08:33
Sharp GX25 can be unlocked?? zakiyyboss FuriouS II 1 11-06-2006 16:41
can anybody confirm if z105 can be unlock by choosing x430 in ust ashvin QUALCOMM Models (3G) 2 08-06-2005 20:55
is this version can be unlocked with furious 3G free ?? chavrotti NEC 21 01-03-2005 10:44
Page generated in 0.55270 seconds with 11 queries
