08-24-2005, 19:33 | #1 (permalink) |
Junior Member Join Date: Oct 2002 Location: Switzerland Age: 44
Member: 16537 Status: Offline Thanks Meter: 2 | I need to reflash a 8330 with 8130 software I just received the Furious Box 2, and there is few things that are strange. - I found a cable IP FD LG8110, is it the correct cable ? Or which one should I use ? (USB + Rj45 cable) - Also the Furious Box 2 has 2 switchesm +5V and M/F BUS, how should I configured them ? - Also should i connect the COM and USB cable to the PC ? Or just one is enough ? - I downloaded the files from furious site, so all seems working. The software opens (well registered etc)... but need to know how the hardware need to be configured. Thank you. TS |
08-24-2005, 22:53 | #2 (permalink) |
No Life Poster Join Date: Dec 2003 Location: United Kingdom, ENGLAND
Member: 47774 Status: Offline Thanks Meter: 185 | 1- How can I do ? Is it possible to see all steps for a newbie ? maybe 2- I found a cable IP FD LG8110, is it the correct cable ? Or which one should I use ? (USB + Rj45 cable) -> Yes its Correct Cable 3- Also the Furious Box 2 has 2 switchesm +5V and M/F BUS, how should I configured them ? -> left button its +5V and right button its F BUS... 4- Also should i connect the COM and USB cable to the PC ? Or just one is enough ? --> yes if u need to unlock Phone or Flashing it with COM port sure u need to connect COM Port. ( but if you want to Start just FuriouS APP u need Connect Only USB and i'm sure u Start FuriouS SW just if u want to unlock Phone so u need allways 2 connect COM Port ) - I downloaded the files from furious site, so all seems working. The software opens (well registered etc)... but need to know how the hardware need to be configured. --> here u found all what do u want Understand about --> http://www.furiousbox.com/inside.php...&model=install BestRegards FuriouSTeam Welcome 2 FuriouS World. |
08-25-2005, 00:05 | #3 (permalink) |
Member: 16537 Status: Offline Thanks Meter: 2 | Thank you ! Thank you for your answer, Just one precision... sorry... About the 2 buttons, there is an option pushed or not, for each of the 2 (near to the USB ports). What should I do ? If I press the 1st one near to the led, one red led turns off. If I press the 2nd button, no led goes off/on. Should I use the 1 and 2 nd button pressed, or not pressed or ... Thank you to precise me more about these 2 buttons. TS |
Please help, need to reflash a ku990 urgently!!! | jowlimowli | LG | 1 | 09-16-2009 23:29 |
903sh need to reflash back to jp version | wahjie | Sharp | 0 | 05-06-2007 11:36 |
Nokia 6650 - Prototype firmware - need to reflash | mobilextreme | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 05-09-2006 13:37 |
Need to reflash Trium MARS | Format1 | Mitsubishi | 0 | 03-05-2001 11:08 |
