07-29-2005, 20:59 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | K300i cid 36 flashing tutorial. 1. Select main file only like K300_MAIN_EU1_R2AL029_CID36.BIN for ex and press FLASH. Shortly press Power button! Detected SonyEricsson: K700/K300/K500/S700/Z500. Status Ok, OTP Close, CID36, PAF1 IMEI: 355795-00-216485 Flash file CID:36 Flashing 206 blocks... address: 44C6A3E0, block: 206/206 D:\K300_MAIN_EU1_R2AL029_CID36.BIN flashed successfully Execution Time - 00:05:20 Done! 2. Press flash and let operation finish and after remove battery and put back. 3. Select fs file only like K300_FS_EU1_R2AL029_CID36.BIN for ex and press FLASH. Shortly press Power button! Detected SonyEricsson: K700/K300/K500/S700/Z500. Status Ok, OTP Close, CID36, PAF1 IMEI: 355795-00-216485 Flash file CID:36 Flashing 73 blocks... address: 45280000, block: 73/73 D:\K300_FS_EU1_R2AL029_CID36.BIN flashed successfully Execution Time - 00:02:06 Done! 4. Press flash and let operation finish and after remove battery and put back. 5. Select finalisation only and press FLASH and select YES on messagebox. Remove battery and put back. Shortly press Power button! Detected SonyEricsson: K700/K300/K500/S700/Z500. Status Ok, OTP Close, CID36, PAF1 IMEI: 355795-00-216485 Flash Finalization Started! Wait while process will be finished! K700/K500 recognized! CsLoader Accepted Ok! System Initialization. Please Wait... Getting data from server... Connection ok! Data recieving... Sign 1 ok. Sign 2 ok. CsLoader Unlocked! Flash Finalization - successfull !!! Execution Time - 00:00:34 Done! 6. Voila you just upagraded firmware/changed language on ur K300i. NOTE: CID 36 files can be used on K300i only. If u intend to flash CID firmwares on k300 then u must use cid 29 to cid 36 transformation file. Br |
07-30-2005, 12:26 | #3 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
07-31-2005, 12:51 | #4 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Sahiwal Punjab , Pakistan
Member: 123133 Status: Offline Sonork: 100.999 Thanks Meter: 911 | ha ha ha dont angry mr hack we knows some people havnt sense to see what they have ,,,and also they search that things that they have in their pockets so guide that people .but dont angry Br Kuku |
08-30-2005, 15:12 | #7 (permalink) | |
Br | |
08-31-2005, 19:09 | #9 (permalink) | |
K700_FS_EMEA1_R2AL029_CID36 and not only. See other _cid36 firms. Br | |
09-02-2005, 02:17 | #10 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | great news i can flash Se k750i to remove voda menu , but i think i need to install win xp sp2 since when im trying to open SEF2BOX.exe it comes with Kernel32 problem . |
k300i cid 36 flash file is here... | saidgoren.com | SonyEricsson (USB-Smart) | 0 | 08-19-2006 08:02 |
K300i Cid 36 Flashing Error !!!! | nabil2000 | FuriouS II | 2 | 11-30-2005 15:54 |
K300i CID 36 flash file | fego | Sony Ericsson | 0 | 11-04-2005 14:37 |
Flash K300i Cid 36 Download | fortipienz | Sonics Box | 9 | 07-11-2005 01:40 |
PLS LEAD I NEED UNLOCK K300i CID 36 | SANTOGSM | Cruiser Suite | 4 | 05-15-2005 00:06 |
