12-06-2004, 17:00 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: mauritius
Member: 15162 Status: Offline Thanks Meter: 61 | Let's find the solution :-Nec 3g CODES PROBLEM.No newbies here All i can say is that furious nec 3g is 100% working have tested on 7 phones till now all went ok.Only one is giving me big problem Even after entering sp code it remains on. if you got this problem that means someone before try the free codes a lot. By playing a bit i found something :- ##3210# =The security lock was permantly turned off ##8140#=corporate lock was permantly turned off ##7320#=network lock was permantly turned off But this also does not help. *3210*#=The codes do not match please re-enter the codes That mean that there should be a solution by code . Now i have just open phone took out the internal battery under the screen and leave it without battery .Will let u know. Hope someone find a solution Cheers Djyash |
12-06-2004, 19:40 | #3 (permalink) | |
Freak Poster Join Date: Aug 2002 Location: BiH, Orasje Age: 44
Member: 14911 Status: Offline Thanks Meter: 13 | Quote:
I have same problem with E228 I already took out internal battery but again nothing I hope so that someone will find solution | |
12-06-2004, 19:50 | #5 (permalink) |
Member: 14911 Status: Offline Thanks Meter: 13 | after desoldering battery for 1h I got cleare memory becouse phone ask from me to setup clock, but again cant enter codes. but we will find solution soon I hope Last edited by GMC; 12-06-2004 at 22:18. |
12-07-2004, 16:34 | #11 (permalink) |
Freak Poster Join Date: Apr 2003 Location: London Age: 42
Member: 25814 Status: Offline Thanks Meter: 1 | I'm probably being very stupid here but have you tried entering the code with a 3 sim in the phone, I have only had 1 like these that you mention and I unlocked it fine by putting sim in and then entering code, says SP lock off, then checked it, still off, even with other SIM! |
12-07-2004, 20:26 | #14 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 54
Member: 92727 Status: Offline Thanks Meter: 0 | Hi, I'm in trouble with my nec e616, First I have to report the response of the phone to some codes : 1)*#2820# (software version) : SW ACPU:A025.36.00 CCPU:C620.R37.K 2) *#06# (IMEI) : IMEI XXXXXX/00 XXXXXX/0 SV00 3) *#7320# network on *#3210# SP off *#8140# off *#4960# usim on Furious server gives me these: IMEI : XXXXXXXXXXXXXXX NCK : #7320*XXXXXXXX# SPCK : #3210*YYYYYYYYY# CP : #8140*ZZZZZZZZ# SIM : #4960*WWWWW# I've tried to enter them without or with usim inserted, but the answer that the phone gives is :" wrong code" or in italian " codice errato" . |
NEC 3g FLASHIN S/W AVAILABLE HERE | hummy | NEC | 2 | 10-03-2006 15:13 |
here is the solution for those which have problems with usb-smart 8,6 | gsm54 | Dongle Problems (USB-Smart) | 0 | 07-16-2006 15:04 |
New NEC 3G Code Reader - the best price on the net! | westerna | Main Sales Section | 0 | 12-02-2004 15:22 |
wanted 100% solution for nec 3g models | x factor | Wanted Products | 11 | 11-01-2004 01:24 |
### HOT : NEC ToTaL Code Reader v2.4 : 359 Euro #### and 32 unlock solution turnkey | gsmfactory | Main Sales Section | 0 | 12-05-2003 00:20 |
