06-26-2009, 22:45 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | be sure u use last update after u clic direct unlock or read code option insert cable to phone, must be auto detected, if not press power on button check ur cable try with read code and direct unlock br <= The_Gorr => |
The Following User Says Thank You to The_Gorr For This Useful Post: |
06-26-2009, 23:30 | #4 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | it's a communication problem, plz check ur cable and also ur phone connector plz also try with some older update, maybe a bug br <= The_Gorr => |
06-27-2009, 01:13 | #6 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | yes but even unlocked, still can't read infos correctly any way, thx for ur report, will sure check and fix this as soon as possible br <= The_Gorr => |
03-25-2010, 15:23 | #7 (permalink) |
Insane Poster Join Date: Jul 2007
Member: 542028 Status: Offline Thanks Meter: 10 | Solution select T456 pres unlock, then connect phone, phone goes in TAT MODE,few seconds and done I used version 238 E210 rj45+USB(both) best regards julio05 |
The Following User Says Thank You to julio05 For This Useful Post: |
Help Unlock S5230 [SOLVED] | Tequilas | PolarBox 3 | 7 | 12-09-2009 17:43 |
need help E63 again [SOLVED] | snowtown | Cyclonebox | 3 | 10-30-2009 14:35 |
need help unlocking toshibo v9 + i need help back | himeyume | Phone Unlocking Codes & Maps | 1 | 05-18-2009 17:38 |
HI I NEED HELP UNLOCKING MY W810i PLEASE HELP.... | kel4jamie142 | Sony Ericsson | 1 | 04-10-2007 12:08 |
need help unlocking P 100 ...plzzz help | dEviLSuKhY | Trident/AGERE Platform | 0 | 02-12-2004 23:14 |
