02-11-2015, 13:45 | #1 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2092068 Status: Offline Thanks Meter: 2 | [HELP] Unlock I9505 finished with error [ANSWERED] Engine Compilation Build : 358 :: Polar Service Software :: ======================= Selected Samsung I9505 ======================= - Phone Status ON - Goto Setup->Applications->Development - Enable USB Debugger For Read Codes 1 - Connect C3300k cable to the phone (powered off) and computer 2 - Wait for phone power on (or power on manually) 3 - After power on, write this secuence *#7284# 4 - Select UART --> MODEM - Use C3305 RJ45 Datacable For Direct Unlock - Type *#0808# -> Select USB -> CP and press OK - Type *#9090# -> Select [1]DM / DUN over HS-USB[] - Use Micro USB Datacable - Reboot Phone 1.- I turned off the phone and later I plug the c3300k, after pressing read codes, nothing happens. 2.- after rooting the phone correctly, and doing *#0808# -> Select USB -> CP and press OK and doing too *#9090# -> Select [1]DM / DUN over HS-USB[] and after pressing unlock the polar box show this log: Engine Compilation Build : 358 Device Data... Model: GT-I9505 Product Code: GT-I9505ZKAATL IMEI: 355172056371139 Serial : R31D916Z7NH S / W Version : 4.4.2 KOT49H Firmware : I9505XXUFNB8 Communicating With Phone via ADB... Reading MM. File... Uploading Data in the phone... Sending Auth... Reading Phone Imei... Finished with Error... what is going on? my box serial is C0007778B14 13:43:35 Connecting with Main Server... 13:43:36 Hi from Polar Server -- 13:43:36 INFO READ 13:43:36 INFO READED -------------------- BOX DATA -------------------- Box SN: C0007778B14 I just bought the LIC1 LICENSE_1 [ Samsung_3G LG ZTE_3G ] : Enabled (Unlimited) thank you |
02-11-2015, 14:03 | #2 (permalink) |
Member: 2092068 Status: Offline Thanks Meter: 2 | Hi again, I discovered by chance when the phone is turned off, and plug the c3300k cable , after I press *#7284#, then pressing MODEM option, and pressing read codes nothing happens, but pressing PDA more Read Codes in polar box, Polar box show this log: Engine Compilation Build : 358 Contacting With Phone ... Connecting... Phone Build : “I~w°óLw Reading SpLock Area... Can't read SpLock Area...Access Denied... Finished with Error... |
