05-29-2015, 09:47 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 54
Member: 84604 Status: Offline Thanks Meter: 22 | i8190n Samsung Factory Work KO [SOLVED] I tried to unlock in this mode but it doesnīt work; here is the log: ====================== 29/05/2015 == 10:38:48 Engine Compilation Build : 364 Contacting With Phone... Phone Model : GT-I8190N S / W Version : I8190NXXANI1 Unique Number : C0890309DB9B450 IMEI : 3565080567xxxxx Serial : R21D64W3B9D Msl : R21D64W3B9 Process Finished Ok... Contacting With Server...Wait... (24210) This service is down or not exists Log Saved... Process Finished With Error Please help. Thanks. |
05-29-2015, 11:22 | #3 (permalink) |
Member: 84604 Status: Offline Thanks Meter: 22 | Yes, I tried. But it tries to root first and no "Yes message" about it appears on the telephone screen, son It canīt be rooted and It canīt be unlocked. Later I tried to root with: iroot: ko kingroot: ko Any ideas (better than flashing) ? Thanks. |
05-29-2015, 12:08 | #4 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Inside PolarBox
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | I think the problem is that you cant root device. Unlock procedure need phone be rooted, once you get will be unlocked without problems. In support we have rooting, but for 4.1.2 version (root_i8190N_4.1.2) In case you have this version, try it and confirm us if worked If different, you need find correct one, i bet will be available on the net With best regards, |
05-29-2015, 17:17 | #5 (permalink) |
Member: 84604 Status: Offline Thanks Meter: 22 | yes, thatīs right, itīs a rooting problem, sure. So, I try to root with your tool, just downloaded from your support (my phone is 4.1.2) But, you havenīt got instructions for doing this, so, how can I do it? thank you very much. |
05-30-2015, 02:42 | #6 (permalink) |
No Life Poster Join Date: Feb 2008 Location: SPAIN
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | Unzip, u have these three files Odin3_v3.04 -(flasher for use flash bellow file) openrecovery-twrp-2.4.2.0-golden - (Flash this file through Odin, select as PDA) UPDATE-SuperSU-v1.10 - (Flash this via SD card). If u never heard or use Odin then check How to flash using Odin and also , Flashing via SD card Do the following, copy last file to sd card or phone memory. flash openrecovery and imediate after flash, flash update-superSU via SD. Also, u can root ur phone using GUI free tool like iRoot or KingoRoot . WBR RotelcaM |
05-30-2015, 10:34 | #7 (permalink) |
Member: 84604 Status: Offline Thanks Meter: 22 | Thanks for the instructions, I know Odin, but I never had unlocked one of this models. Iīll try now. As I told you in my previous message, kingoroot and iroot didnīt worked. Thanks again. |
05-30-2015, 14:41 | #8 (permalink) |
Member: 84604 Status: Offline Thanks Meter: 22 | Sorry. I did the first step ok, but when I try install the package superSU from sdcard: E:failed to verify whole-file signature E:signature verification failed Help, Thanks. |
05-30-2015, 14:53 | #9 (permalink) |
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | U should allow phone reboot to normal after flashing recovery. Before flashing, make sure sdcard prepared inside phone, u may untick reboot in Odin, or quickly manual press combination to put phone in recovery mode immediately flash finish. Success! |
The Following User Says Thank You to rotelcam For This Useful Post: |
05-30-2015, 15:11 | #10 (permalink) |
Member: 84604 Status: Offline Thanks Meter: 22 | Yes, "Auto-Reboot" Odin problem. With these more clear instructions, in only 3 minutes the phone is unlocked. Perhaps it could be a good idea for all (us, the customers, and you, the support) to put a little .txt file with real instructions for every root in support section. You know, time is gold for all (us and you). Thank you very much. |
05-30-2015, 15:29 | #11 (permalink) |
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | For sure, this ocourse only to this model, i9195 .... n some older with android 4.1.2. [Headache 4.1.2 ]. Searching forum is another greater idea. For this must have been posted several times. All the same. Welcome! n thank for ur patience. WBR RotelcaM |
