06-04-2014, 18:55 | #1 (permalink) |
Junior Member Join Date: Apr 2007
Member: 483767 Status: Offline Thanks Meter: 0 | I9505 unlock problem [ANSWERED] Compilation Engine Build : 347 Polar Service Software :: :: ======================= Selected Samsung I9505 ======================= - Phone Status ON - Goto Setup- > Applications- > Development - Enable USB Debugger For Read Codes 1 - Connect to the wire C3300k phone ( powered off) and computer 2 - Wait for phone power on ( power on or manually ) 3 - After power on , write this secuence * # 7284 # 4 - Select UART -> MODEM - Use C3305 RJ45 Datacable For Direct Unlock - Type * # 0808 # - > Select Modem + DM + ADB and press OK - Type * # 9090 # - > Select [1 ] DM / HS- USB DUN over [ ] - Use Micro USB Datacable - Reboot Phone I try both ways Read Codes / Direct Unlock Read Codes but did not find the lyrics (not found) and Direct Unlock the mobile gives me an error when selecting Select [1 ] DM / DUN over USB HS- (*) and restarts. I selected usb debugging mode , the mobile SuperSU this roteeado with firmware V.194 and I9505XXUFNC4 I have also tried to release it by * # 0011 # service mode but I think it only works with 4.3 Do you know if I can release it with root terminal? Any idea ? Thanks for everything. regards |
06-05-2014, 13:44 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: SPAIN
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | Hi, If phone is not rooted 100% won´t be detected for unlock process. i advice you reset phone and root with apropriate root. Can use this rooting tool VROOT. Remember to make a gesture () to that. best regards RotelcaM |
