09-27-2012, 21:29 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2006
Member: 220082 Status: Offline Thanks Meter: 2 | ot 918a not conect polar box [ANSWERED] second press button conect reconect usb not read conect baterry y waiting drivers in box |
09-27-2012, 23:32 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Inside Polar Box
Member: 71492 Status: Offline Thanks Meter: 119 | This is process Phone Off with battery Press Connect or Read Codes You see Please Plug Cable in Phone and Wait...... In this moment need install driver Terminal port appears within seconds At this time you should install driver Depending on whether you need Read Codes or Flashing phone you need to install a second driver Regards |
09-28-2012, 16:03 | #4 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: Inside PolarBox
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Quote:
Hi nikolai_vigo, Sorry but drivers in support was not correct. I uploaded now another drivers that will work and detect phone (i tested here myself) Please, try again and post if success. When 2 devices appear, make UPDATE DRIVER in the "CDC Serial" and later choose *.INF manually. After install polar will detect and read codes. Regards, \W3nd|g0 | |
The Following User Says Thank You to wendigo For This Useful Post: |
10-25-2012, 15:33 | #5 (permalink) |
No Life Poster Join Date: Feb 2010 Location: FROM-PERÚ
Member: 1242979 Status: Offline Sonork: ☻9-9126-6305☻ Thanks Meter: 337 | Unlock done alcatel 918a by Polar NCK Code : 22200645 Spck Code : 33246139 Nsck Code : 28610187 Sim Code : 34069921 Cck Code : 32936850 Insert Not supported Sim In The Phone Power ON Type You Code in Keyboard Press OK Key Calculated Codes...OK... Last edited by mobile_zone1; 10-25-2012 at 15:39. |
The Following User Says Thank You to mobile_zone1 For This Useful Post: |
11-12-2012, 15:37 | #7 (permalink) |
Major Poster Join Date: Dec 2011
Member: 1703991 Status: Offline Thanks Meter: 5 | i got unlock code but when i put non-supported sim, where enter to code, apprear for a second and then disappear again...please advice how to enter code. i tried *0000*code# & *0001*code# but not work... |
12-14-2012, 01:57 | #10 (permalink) |
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | ================================================== ================== Instructions installing drivers - English language -------------------------------------------------------- Models affected : 916 918 922 928 966 985 991 992 A919 A966 A986 C918 C919 MOV2 V861 W939 W969 Models affected : MomoDesign MD Smart, Orange Pasadena, ZTE Mimosa mini V856/V857 ================================================== ================== - Open Control Panel and go to device manager - When phone be detected : Select this folder "C:\Drivers_Alcateles_Android_MTK\Alcatel_Android_ MTK_USB VCOM Driver" for computer install drivers, this folder have all for enable high speed port. - Folder "Alcatel_CDC_USB_Driver", have only CDC driver. This driver is ONLY used for READ CODES function. IMPORTANT : Alcatel driver only appears 4-5 seconds, when you plug phone and later disappears quickly. You must put attention for install it fast. ================================================== ================== Instrucciones instalación drivers - Spanish language ------------------------------------------------------------- Models affected : 916 918 922 928 966 985 991 992 A919 A966 A986 C918 C919 MOV2 V861 W939 W969 Models affected : MomoDesign MD Smart, Orange Pasadena, ZTE Mimosa mini V856/V857 ================================================== ================== - Abrir Panel de Control e ir al administrador de dispositivos - Cuando el telefono sea detectado : Selecciona la carpeta "C:\Drivers_Alcateles_Android_MTK\Alcatel_Android_ MTK_USB VCOM Driver" como origen para que coja los drivers de alli. Esto carpeta contiene los drivers necesarios para conectar el terminal y para el puerto de alta velocidad. - La carpeta "Alcatel_CDC_USB_Driver", contiene unicamente el driver CDC. Este driver se utiliza SOLAMENTE para la función de READ CODES IMPORTANTE : El driver de alcatel aparece solamente 4-5 segundos cuando pinchas el telefono y despues desaparece rápi*****te. Has de estar bien atento e instalarlo muy rápido. |
12-29-2012, 18:54 | #11 (permalink) |
Junior Member Join Date: Mar 2012 Location: las palmas de gran canaria
Member: 1728833 Status: Offline Thanks Meter: 0 | hola me podrias ayudar? intento instalar drivers para smart2 que me descargue del support pero me dice mi pc que no encuentra el driver, tambien lo he intentado instalar manualmente en administrador de dispositivos y no hay manera, gracias |
12-29-2012, 20:19 | #12 (permalink) |
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Hi, One very important thing, this model only can be unlocked under 32bits systems (WinXP 32bits, Win7 32bits), due drivers not works over 64bits systems. If your computer is 64bits, you will need to find one with 32bits. After this, all will work (is totally supported) With best regards, |
12-29-2012, 20:20 | #13 (permalink) | |
Phone will be unlocked, and unbranded. This will solve your problem. With best regards, | |
