pantech c520 How to enter unlock code ? [SOLVED] how to enter codes in pantech c520 when i put a non accepted sim only sos softkey enabled so anybody know how to enter codes ? also i try too in 1410 and c150 still same only sos thanks in advance b.r aleon |
try this : *01763*6371# 1 - Insert non-accepted SIM card 2 - Power on the device 3 - The display will show "Change SIM" and Left Soft Key will be labeled "Unlock" 4 - Press Left Soft Key - A "Password" box will appear on display 5 - Enter Unlock Code 6 - Press "OK" - Center Soft Key The device will display "rebooting" and then power cycle 7 - The device is now unlocked br <= The_Gorr => |
1.POWER ON PHONE WITH ACCEPETED SIM CARD 2.Press the following keys: *#865625# 3.A SIM Unlock Menu will appear, press OK 4.Enter Unlock Code (8 digit code)* 5.Re-enter Unlock Code (8 digit code)* 6.YOUR PHONE will display Unlock Process Complete. Press OK. The PHONE is now unlocked WITH BEST REGARDS,SUUNNYY BR.;) |
i try in pg-1410 with not accepted sim card left soft key not enabled only change sim and right soft key sos wit accepted sim card type *#865625# but not works ...only values that i pressed before any other way i appreciate your helps thanks in advance b.r aleon |
i tested today because dont have phones in my hands later thanks one more time to suunnyy and the gorr for your help b.r aleon PROBLEM SOLVED |
Does the Polar Box supports unlocking Pantech C520? Thanks, |
pantech c520 permanently locked what about the phone that is permanently locked when entered this code , is there any reset to normall mode as i gopt the phone permanently locked all 5 times tried and failed, can u help me reinitialised this phone to virgin state plzzzzzzzzz Quote:
Means counter blocked,for the moment no solution for this,regards,suunnyy |
is this code working for all pantech phones? |
Thanks Brother |
