06-14-2009, 21:57 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | ★★★ PolarBox : FAQS & HELP ★★★ > How to install PolarBox2 Suite (in 3 easy steps) < STEP 1) First of all, download and install this software (Last PolarBox2 software) Be sure you not have connected box, because at this step is not necesary PolarBox2 Installer for METAL VERSION (all drivers inside) PolarBox2 Installer for PLASTIC VERSION (all drivers inside) STEP 2) After software has been properly installed, please plug your PolarBox2 in your computer and wait till windows request drivers (start detection). When your system start to ask you for drivers, select correct path in your computer. Example (english windows) : C:\Program Files\Polar Box\Drivers Example (spanish windows) : C:\Archivos de programa\Polar Box\Drivers Windows will finish detection and installing of drivers, and will confirm you in few seconds, now your box is installed. STEP 3) At this step, box and drivers are properly installed but in order to use server services you need make a last step. This process is the "Box Registration" and not takes excesive time (only few seconds) Now run POLAR-SAT software (already installed) and go to SETUP Fill this form with all your details and confirm it. After this, your PolarBox2 is registered, process is in real time and you not will receive any mail of confirmation. VERY IMPORTANT !!! Please, try to have always installed our last update version Server only works properly with last versions of software, then keep you informed and install it every update For last versions execute POLAR-SAT and press SUPPORT FILE SERVER button (you will access to download area) Now, enjoy your PolarBox2 :-) Thanks in advance for your attention, With best regards, [ Polar Team ] [ Http://www.polarbox2.net ] [ Http://www.nano-box.eu ] [ Http://www.bb-box.net ] [ Http://www.polarteam.net ] [ Http://www.auto-polar.com ] HOW TO MAKE A SCREEN CAPTURE 1: use ur keyboard button 2: open windows paint and paste ur image 3: save ur image 4: final step br <= The_Gorr => Last edited by FullFLASHgSMPH; 02-12-2011 at 02:32. |
The Following 11 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 22:08 | #2 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | How to upload image on forum HOW TO UPLOAD IMAGE ON FORUM 1: go to http://photobucket.com and make registration 2: after registration, login to ur account and enter to my albums 3: clic on choose file and select ur image 4: wait until image will be uploaded to web site 5: after success upload, clic on return to album 6: now copy ur image link (direct link) 7: make a new post in forum and insert ur image direct link 8: final step, now ur post is ok with ur image |
The Following 13 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 22:16 | #3 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | HOW TO MAKE UNSUPPORTED PHONE, SUPPORTED BY POLAR BOX 1- GIVE US PHONE MODEL 2- GIVE US PHONE INFOS 3- READ FULL FLASH AND UPLOAD TO RAPID SHARE 4- POST UR RAPID SHARE LINK EXEMPLE |
The Following 8 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 22:20 | #4 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | U CAN'T ENTER TO SUPPORT USING POLAR SUITE !! THEN HOW TO ENTER !! 1- RUN SAT 2- SELECT SUPPORT - FORUMS 3- CLIC SOFTWARE, UPDATES ... TO ENTER DIRECTLY TO SUPPORT Last edited by The_Gorr; 07-15-2010 at 00:42. |
The Following 10 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 22:23 | #5 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | U HAVE ERROR File System Not Found WHEN U INSTALL LAST UPDATE ? 1- GO TO THIS LINK HERE 2- DOWNLOAD AND INSTALL LAST INSTALLER V17 3- DOWNLOAD AND INSTALL LAST UPDATE 4- ALL IS OK NOW Last edited by FullFLASHgSMPH; 06-19-2010 at 05:08. |
The Following 7 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 22:34 | #6 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | ★★★ How to register PolarBox2 / Download Last Update/Download and Install Area Last edited by The_Gorr; 02-12-2011 at 18:28. |
The Following 29 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 22:39 | #7 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | HOW TO ENTER UNLOCK CODE IN SAMSUNG I900 OMNIA > 1. Insert an unaccepted SIM card > 2. Enter the pin code to simcard > 3. At the top of screen an "exclamation mark" icon will appear > 4. Click on "exclamation mark" icon > 5. There will appear link "settings" - click on it > 6. Virtual keyboard appears on screen with Enter PIN prompt. > 7. Enter your 8-digit unlock code It does not show an exclamation mark, but a lock simbol with the letters NET; this comes with the following notification: Network lock", and the options: "OK"; "dismiss". When I press OK, it gives me the virtual keyboard: then I insert the code and it works. |
06-14-2009, 22:42 | #8 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | alcatel s920 / s920x can't be detected by polar and computer not ask for drivers 1- just remove ur memory card from phone 2- plug ur usb cable again 3- install drivers |
06-14-2009, 22:44 | #9 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | SOME PHONES CAN'T BE DETECTED BY POLAR USING USB CABLES 1- be sure only polar is connected to ur computer (no other dongle or box) 2- change phone port number to any number under 10 |
06-14-2009, 22:48 | #10 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | I USED SOLDERING WIRES (RX, TX, GND) NOW MY BOX IS DAMAGED POLAR SOFTWARE CAN'T RUN / OR CAN'T CONNECT PHONES ANY MORE I HAVE A BAD USB POWER / HUB NOW MY BOX IS DAMAGED POLAR SOFTWARE CAN'T RUN / OR CAN'T CONNECT PHONES ANY MORE 1- IF UR BOX IN UNDER WARRENTY THEN BETTER CONTACT UR RESELLER 2- IF UR BOX IS OUT OF WARRENTY THEN U CAN REPAIR IT IN FEW MINUTES JUST BY CHANGING FTDI POLAR FTDI IS SAME AS UFS, TWISTER, NBOX .... OR ANY FTDI DEVICE Last edited by The_Gorr; 09-02-2009 at 14:05. |
The Following 19 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 23:01 | #11 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | I CAN'T USE POLAR SERVER, ALWAYS HAVE THIS ERROR A07 check account 1- UR BOX HAVE TO BE REGISTRED WITH SAT (U HAVE TO REGISTER) 2- U NOT SAVE UR LOGIN AND PASS IN SAT OR U PUT A WRONG LOGIN AND PASS IN SAT (PUT CORRECT INFOS) 3- U USING A ANTIVIRUS THAT BLOC UR CONNECTION (DESABLE IT) 4- U HAVE A FIRWELLED CONNEXION (DESABLE IT) |
06-14-2009, 23:05 | #12 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | I HAVE SAGEM LOGS, CAN I USE THEM ALSO TO UNLOCK MODEMS !!!! Yes u can now we can't talk about sagem logs, we talk about polar credits, with polar credits u can unlock any phone need credits |
The Following 6 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 23:12 | #13 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | I UNLOCKED SOME PHONES NOT EXIST IN SUPPORTED MODELS, BUT UNLOCKED OK USING POLAR BOX congratulation, but we need some infos 1- post phone model 2- post what model u selected from polar phone list 3- post what cable u used to connect it 4- post a screen capture or paste log of unlock process 5- read full backup, upload it to rapidshare and post link (if possible) |
06-14-2009, 23:19 | #14 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | MY PHONE IS SUPPORTED BY POLAR, BUT I DON'T HAVE CABLE 1- U CAN BUY CABLE 2- CHECK SUPPORT FOR PINOUTS 3- CHECK THIS THREAD IT CAN HELP U ALSO link |
06-14-2009, 23:24 | #15 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | I DON'T HAVE CABLE, BUT HAVE PINOUT, HOW TO FIND RX, TX, GND IN POLAR RJ45 !! POLAR HAVE UNIVERSAL PINOUT, SO ANY UNI CABLE CAN WORK PERFECTLY USING POLAR ABOUT POLAR RJ45 PIN, U CAN REFER TO THIS IMAGE |
The Following 12 Users Say Thank You to The_Gorr For This Useful Post: |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
