02-06-2014, 21:10 | #1 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2122900 Status: Offline Thanks Meter: 0 | polarbox 3 wont connect phones [ANSWERED] i received a polar box 3 today,all the drivers installed correctly,it's registered,the software works but i have now connected 3 phones and it says this every time Engine Compilation Build : 340 Model Selected I9300 Searching Device in Modem Port... Modem Port Not found... Initializing ADB.... ADB Initialized...Searching Device... Device Not Found...0 Phone Not Connected... usbdebugging is enabled and i have followed all the instructions are the phones knackered or am i doing something wrong?? do you just have toinstall the drivers and it's good to go,or doyou have to dosomething else?? thanks in advance :-) |
02-06-2014, 21:45 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Quote:
http://www.youtube.com/watch?v=zOW7noE0_Cg Regards | |
02-06-2014, 23:44 | #4 (permalink) |
Member: 2122900 Status: Offline Thanks Meter: 0 | i installed a quolcomm driver and now it says this Engine Compilation Build : 340 Model Selected I9305 Searching Device in Modem Port... Initializing ADB.... ADB Initialized...Searching Device... Device Not Found...0 Phone Not Connected... when it starts initializing ADB the lights on the box go out and then it says device not found i find it had to beleive the box comes with no instructions i have don a diagnostic on the box using polar sat and it says everything is ok.....it's not.....help! i thought this was going to be easy |
02-06-2014, 23:56 | #5 (permalink) | |
http://forum.gsmhosting.com/vbb/f386...olved-1698250/ Regards | |
02-07-2014, 11:30 | #7 (permalink) |
Insane Poster Join Date: Sep 2013
Member: 2028513 Status: Offline Thanks Meter: 5 | Do you follow the polar box's instructions? - Phone Status ON* - Use Micro USB Datacable * * - Goto Setup-> Applications-> Development * - Enable USB Debugger * - Reboot Phone very important * - Type * # 7284 # * - Select UART -> Modem * - Type * # 9090 # * - Select Opt [4] -> DM over UART * - Reboot Phone * - Plug Micro USB Cable Apparently is a problem of adb drivers if you have not installed samsung drivers, you must do it. |
