Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3
Old 09-02-2009, 16:56   #1 (permalink)
Member: 72515
Thanks Meter: 27
Problem to Unlock Samsung E250v.Canīt see codes and unlock directly ::: SOLVED :::
Connecting Phone..Wait...
Phone Imei : Error
Phone S/W : E250BGFL2_FL
Phone H/W : 3
Network : 000BB
Net Code : #7465625*638*FFFEFFF9#
Sub Code : #7465625*782*FFFEFFF9#
SP Code : #7465625*77*FFFEFFF9#
CP Code : #7465625*27*FFFEFFF9#
UnFreeze Code : FFFEFFF9
Phone Code : FFFEFFF9
And if I try to unlock directly, Polar soft give me "Phone not unlocked.....:"
Whatīs the problem? I selected model E250v and I used D800 cable
Regards
Codes Readed Ok...
Old 09-02-2009, 17:58   #2 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
Phone Imei : Error
Phone H/W : 3
Network : 000BB
Regards
Codes Readed Ok...
HI FRIEND TRY THIS CODE Net Code : #7465625*638*00000000# ALSO TRY READ CODES SELECTING E250 ALL THE BEST,SUUNNYY
Old 09-02-2009, 20:10   #3 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
try using last update v2.2.2
br
<= The_Gorr =>
Old 09-02-2009, 21:14   #4 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
It seems to me cable problem, anyways try selecting another model like E250, luck
Old 09-04-2009, 23:05   #5 (permalink)
Member: 453324
Thanks Meter: 54
no this is not cable problem brother sure just select e250 not e250v and press unlock your mobile will be unlocked.
Old 09-05-2009, 03:42   #6 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,012
some E250i, when switched on, they display E250V on screen, so perhpas u confused
Think Belli42 gave solution...Just try Other model (E250, E250i...) and post result
WBR,
Old 09-05-2009, 05:09   #7 (permalink)
wendigo's Avatar
Member: 10286
Sonork: 100.90962
Thanks Meter: 4,353
Phone Imei : Error
Phone H/W : 3
Network : 000BB
Regards
Codes Readed Ok...
Hi friend,
Select E250 and press DIRECT UNLOCK
Phone will be unlocked ...
With best regards,
\W3nd|g0
PD Today I unlocked 4 pcs of this ....
Old 09-05-2009, 17:29   #8 (permalink)
Member: 72515
Thanks Meter: 27
Solved
Originally Posted by wendigo View Post
hi friend,
select e250 and press direct unlock
phone will be unlocked ...
With best regards,
\w3nd|g0
pd today i unlocked 4 pcs of this ....
solved
thankx peter
The Following User Says Thank You to Grupo MovilFree For This Useful Post:
Old 09-05-2009, 18:57   #9 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
Originally Posted by grupo movilfree View Post
solved
thankx peter
good to see this problem solved,polar team rocks:dsuunnyy
Old 09-06-2009, 14:37   #10 (permalink)
wendigo's Avatar
Member: 10286
Sonork: 100.90962
Thanks Meter: 4,353
In this phones Samsung not put things very clear ...
You can see in label E250i and when u power on u see in screen E250V
Same for others E250 (normal) that when you try to unlock you need to make E250V (read codes) process.
Then I recommend make E250 (direct unlock process) or E250V (read codes), one of this must works.
If not, there is a E250i :-)
With best regards,
\W3nd|g0
Can not unlock samsung L760v ::: SOLVED ::: djouaka PolarBox 3 13 08-28-2009 08:00
problem to unlock KG275? [SOLVED] husainm PolarBox 3 5 08-18-2009 18:00
f480 security code any one can help!! ::: SOLVED ::: topcom37 PolarBox 3 21 03-14-2009 13:27
canīt unlock samsung U700B ::: SOLVED ::: paulav PolarBox 3 1 03-12-2009 16:09
Canīt Unlock Samsung E250v Vodafone Spain ::: ANSWERED ::: Grupo MovilFree PolarBox 3 1 12-12-2008 21:58
Page generated in 0.21530 seconds with 9 queries
