Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3
Old 11-27-2009, 17:39   #1 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
Put in this thread all unlocked phones that not exist in models list/Any corrections
Hi TO ALL,
please post in this thread all unlocked phones that not exist in supported list, but success unlocked selecting other models
Wha we need here :
1- screen shot if possible
2- log of unlock procedure
3- cable used and phone selected
4- tricks if exist
5- if firmware or country or any infos was readed wrongly please also post correct one.
POST OUT OF THIS TOPIC WILL BE DELETED
thx in advance,
br
<= The_Gorr =>
The Following 9 Users Say Thank You to The_Gorr For This Useful Post:
Old 11-27-2009, 18:54   #2 (permalink)
Yaio's Avatar
Member: 256260
Thanks Meter: 726
Polar Suite 2.31
LG CG225 and CG225trf unlock Ok..using the same data and procedures
Select C1300i (Ti Basec)
Cable Lg7050
Direct unlock tested 100%
lost the log.
LG C2000 select C1300i unlock ok.using the same data and procedures. Cable Lg 7050.
This on list the model tested select other model...:
Huawei T211 select T201. unlock tested.using the same data and procedures
Samsung A516 select A517 and read codes 100ok.using the same data and procedures
Samsung T456,T459 direct unlock select E210 .Tested.using the same data and procedures
Samsung E2210,E2210L select E2210B.unlock 100ok.using the same data and procedures
Samsung N620 select R2xx
phone on.
cable E700
direct unlock.
The Following 6 Users Say Thank You to Yaio For This Useful Post:
Old 11-27-2009, 21:17   #3 (permalink)
Member: 1169642
Sonork: 1587581
Thanks Meter: 234
PLAY BOY phone unlocked ok selecting ALCATEL OT V770
after reaching long time i have recovery if polar box can unlock this phone
i used V770 cable ,then frash with ot V770 firmware.phone unlocked ok
phone is this
this is log
The Following 8 Users Say Thank You to GSM SOLUTION. For This Useful Post:
Old 11-27-2009, 22:06   #4 (permalink)
Member: 592237
Thanks Meter: 21
unlock e225a
only need select e230 model click conect and after click on read codes with e101 cable polar is the best
The Following 7 Users Say Thank You to la m3nte For This Useful Post:
Old 11-27-2009, 23:53   #5 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Thanks Meter: 12,673
ZTE MomoDesign-2 is same that Amoi MomoDesign-2 "Amoi MD-2" in supported list.
This phones say: ZTE MD-2 under battery.
- Phone Status ON
- Use ZTE F230 USB Datacable
- Drivers_Amoi_MD2 from our support
- Select in: Amoi/Lg: Amoi MD-2
- Important TRICK: enter a test sim, go Connection settings in menu and set communication mode to USB if PolarBox2 not detect drivers.
- All info readed OK.
br
elcapitel
The Following 5 Users Say Thank You to elcapitel For This Useful Post:
Old 11-28-2009, 00:41   #6 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Thumbs up Alcatel C65 unlock Ok select E805 model
Alcatel C65 is same that Alcatel E805, to put in list...
thank to @bautizo for test.
log:
Connecting Phone..Wait..
Flash ID.: 017E0201 , AMD 16 Mb.
Phone Type : E805
Phone S/W Version : E805X-2ATMPT1
Operator / Country: TMN / PORTUGAL
Languages : EN FR DE PT ES
Phone IMEI : 352xxxxxxxxxxxxx
Phone Conected Ok..
Unlocking Phone ...
Reading SpLock Zone...
Reading SpLock...Ok
Backup SpLock File Saved..
Writing SpLock Zone...
Unlocking DONE...
- Phone Status OFF
- Use Alcatel OT-Exxx Datacable
- Info readed Ok.
br
elcapitel
The Following 6 Users Say Thank You to elcapitel For This Useful Post:
Old 11-28-2009, 19:29   #7 (permalink)
Yaio's Avatar
Member: 256260
Thanks Meter: 726
Look.Samsung A516 select A517 and read codes 100ok.using the same data and procedures
The Following 3 Users Say Thank You to Yaio For This Useful Post:
Old 11-28-2009, 19:32   #8 (permalink)
Yaio's Avatar
Member: 256260
Thanks Meter: 726
forget.
W156 full tested select W160.using the same data and procedures
Read/Write ok..
Unlock 100%ok.
Old 11-28-2009, 19:38   #9 (permalink)
Yaio's Avatar
Member: 256260
Thanks Meter: 726
Cable Lg7050
lost the log.
The Following 2 Users Say Thank You to Yaio For This Useful Post:
Old 11-29-2009, 19:26   #10 (permalink)
Yaio's Avatar
Member: 256260
Thanks Meter: 726
These are other models completely proven by other polaruser.
LG MG 296 select MG 295. unlock tested.using the same data and procedures
LG KP 260 select KP 265. unlock tested.using the same data and procedures
LG CG 300 select KG 810 unlock tested.using the same data and procedures
LG KG 208 select KG 810 unlock tested.using the same data and procedures
ZTE
ZTE A933+ select Vdfone 225.unlock tested.using the same data and procedures
SAMSUNG
SAM E1105T select e1310m .unlock tested.using the same data and procedures
SAM S401 select X500 .unlock tested.using the same data and procedures.
SAM A117 select B110.unlock tested.using the same data and procedures.
These are model completely proven by other polaruser. i their log like test of the test has already been posted with pictures
in the case of the samsung the codes are not fiables.when the imei it is to zeros 0000000000000000.en some countries they are not able to sircular(for law)we need reliable solutions.
thank you polar team.
Old 11-30-2009, 16:00   #11 (permalink)
urecel's Avatar
Member: 520810
Thanks Meter: 231
Flash ID.: 017E3022 , AMD 16 Mb.
Firmware Ver. : 192
Phone Type : V670A-2ARGDO1
Operator/Country : Unknow / Unknow (Orange Dominicana) (37001)
Language : Unknow (English, Espanol, Portuguese BR, Italiano, Francais)
Phone IMEI : 011492-00-306792-9
Backup File Saved..
Phone Connected Ok..
Contacting With Server...Wait...
Credits Consumed : 0
Nck Code : 3225100977
Spck Code : 1259382075
Insert Not supported Sim In The Phone
Power ON
Type You Code in Keyboard
Press OK Key
Calculated Codes...OK...
Phone Disconnected ...
The Following 2 Users Say Thank You to urecel For This Useful Post:
Old 11-30-2009, 18:24   #12 (permalink)
yozh's Avatar
Member: 87284
Thanks Meter: 23
hello just to let you know that I unlocked an LG CG225 using polarbox2 so you might add the model to the suite.
Model: LG G-4011
Cable: LG 7050
heres the log
Please Wait..Sending Boot ...
Flash ID.: 017E2100 , AMD 16 Mb.
IMEI : 011081-00-416070-8
Phone S/W : G4050_SWVer_
Phone Connected OK....
Reading NCK..
NCK Code: 154
Insert incorrect sim and type NCK Code + OK
Please Wait..Unlocking ...
Some phones SouthAmerican after unlock
phone still locked.
You must flash phone using any Firmware
in polar support.
After this, repeat unlock process and
phone will be unlocked
Phone Unlocked OK....
Enter 2945#*# without a sim inside
and select 'Fact. Reset'.
please add support for km380 and g180 there are a lot outside
thanks
The Following 2 Users Say Thank You to yozh For This Useful Post:
Old 12-06-2009, 17:27   #13 (permalink)
bigboy85's Avatar
Member: 682554
Sonork: 1601123
Thanks Meter: 222
hello mates i have unlocked 2 huawei u7315 from movilnet venezuela this way:
just need to connect the phone without simcard inside with cable USB VODAFONE 810
selec model HUAWEI U7310
then press read codes button and it will give you the unlock code
put any simcard and type the NCK readed by POLAR BOX
here is my picture:
thanks to polar team especialy mr the gorr for support i apreciate it
enjoy using POLAR BOX
The Following 3 Users Say Thank You to bigboy85 For This Useful Post:
Old 12-07-2009, 21:12   #14 (permalink)
WILUNLOCK's Avatar
Member: 726741
Thanks Meter: 1,256
Unlock e1085 Direct Unlock Seleccting Model E1075L and Unlock OK
Reading Phone Data....
Phone type E075L
Phone S/W : E0…-šX°˜QÒZ:$\
Phone H/W : • fRRutëdz n
Phone IMEI : 012015-00-140188-8
Reading Simlock Zone....
Simlock Backup Saved...
Calculating Data.....
Writing Simlock Zone...
WILUNLOCK
The Following User Says Thank You to WILUNLOCK For This Useful Post:
Old 12-15-2009, 22:36   #15 (permalink)
Member: 453324
Thanks Meter: 54
team plz correct in the sofware bcoz f200 is not like that its unlocking like f210 or u can unlcok by selecting f210 bcoz the option u give to unlock f200 is not possible in that why to unlock this mobile.i unlock sucesffully by selecting f210 thanx.
Searching Phone Please Wait ...
Phone S/W Version: F200XXGG6
Phone Imei: 355857-01-006549-2
Unlocking Please Wait...
Phone Is Unlocked Ok...
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. hitibiti Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2837 07-05-2020 10:10
Put in this thread all successfull story with Cyclone-box NADEEM GONDAL Cyclonebox 3058 05-24-2019 07:07
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box FullFLASHgSMPH Cyclonebox 2 04-13-2009 14:00
Page generated in 0.34172 seconds with 10 queries
