03-03-2014, 14:25 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 54
Member: 84604 Status: Offline Thanks Meter: 22 | s3 no connect [SOLVED] Model Selected I9300 Searching Device in Modem Port... Initializing ADB.... ADB Initialized...Searching Device... Device Not Found...0 Phone Not Connected... Hello. Drivers installed ok in a ok working computer. usb debug enabled. uart modem and usb pda enabled android 4.3 i9300xxugmk6 IF I TYPE *#9090# OPTION 4 IS NOT DM over UART, MY OPTION 4 IS RAMDUMP OFF phone still is not rooted thanks. |
03-03-2014, 17:16 | #3 (permalink) |
No Life Poster Join Date: Feb 2008 Location: SPAIN
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | 4.3, must root phone and imput *#7284# select UART modem, USB pda. your 4.3_root flash with odin and unlock your phone. WBR RotelcaM |
03-03-2014, 19:23 | #4 (permalink) |
Member: 84604 Status: Offline Thanks Meter: 22 | ok, thankyou very much, rotelcam. Now its rooted but still doesn´t connect. Drivers seem to be ok In my first post I wrote this: "IF I TYPE *#9090# , option 4 IS NOT "DM over UART", MY OPTION 4 IS "RAMDUMP OFF" Why this is different from the instrucctions? If I make a hard reset, does the phone continues rooted? Thanks again. |
03-03-2014, 19:33 | #5 (permalink) | |
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | Quote:
Btw you not need hard reset, just do #*0808# on that menu select just mtp+usb and power off phone, remove battery for 30 seconds, restart pc. start phone and connect to pc, then start polar suite and do unlock. If all not success and you have nothing to loose in phone, then do hard reset and re-root phone then unlock success. i found this connection probem use too occour with phone prevously having user cache absolute. WBR RotelcaM | |
03-04-2014, 14:52 | #6 (permalink) |
Member: 84604 Status: Offline Thanks Meter: 22 | finally I made hard reset because when I did this you told me: ... do #*0808# on that menu select just mtp+usb ... what I saw in the screen was : usb: ap usb settings: mtp+adb So I made hard reset but everythings is equal: polarbox no connect and *#0808# shows me mtp+adb , not mtb+usb as you told me. Another thing: some times before hard reset but too after hard reset, phone shows this message: com.sec.android.app.clockpackage stopped. thanks. |
03-05-2014, 09:25 | #8 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | needed drivers are inside support and 100% working. i suggest u to use a clean fresh installed windows, cause maybe u have a drivers conflict. also u can select phone com port manually in polar software and check if detected. Br |
03-06-2014, 15:32 | #9 (permalink) |
Member: 84604 Status: Offline Thanks Meter: 22 | sorry - I select VCOM mannually: COM56-SAMSUNG Mobile USB Modem but: Engine Compilation Build : 342 Model Selected I9300 Modem Port Not found... Initializing ADB.... ADB Initialized...Searching Device... Device Not Found...0 Phone Not Connected... This is driver info in xp device manager: SAMSUNG Electronics Co., Ltd. 14/08/2013 2.11.1.0 Microsoft Windows Hardware Compatibility Publ and ssudmdm.sys: DEVGURU Co ltd 2.11.1.0 Copyright devguru 2002-2008 please, which is the file with right drivers for this model in support section? Thanks. Sorry: I´ve got kies 3.2 |
03-06-2014, 16:10 | #10 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | use i9xxx drivers or simply use download and install kies. u can test also these one : Samsung Andorid USB Driver for Windows | SAMSUNG Developers Br |
03-09-2014, 11:02 | #12 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Inside Polar Box
Member: 71492 Status: Offline Thanks Meter: 119 | Quote:
Please sendme you backup or backups files located in you \backups\samsung\ folder You can locate this files for imei number [email protected] Regards | |
03-09-2014, 11:04 | #13 (permalink) | |
- Enable USB Debugger - Reboot Phone Install driver Regards | |
03-10-2014, 10:30 | #14 (permalink) |
Member: 84604 Status: Offline Thanks Meter: 22 | Hello. In other computer: same problem. I downgraded phone to 4.1.2 with odin 1.8.5 but now the phone restars all the time. i used this firmware: I9300XXEMC2_I9300YOGEMD1_I9300XXEMC2_HOME.tar.md5 please, help. |
03-10-2014, 10:37 | #15 (permalink) |
Member: 84604 Status: Offline Thanks Meter: 22 | Fistro, I´ve made everything you say, in two computers, but software doesn´t connect with phone. Now I´ve flashed it to older version for trying to unlock but now phone restarts all the time (I tiked "Auto Reboot" and "F.Reset Time" and selected "PDA" żbut perhaps I made something bad?). I haven´t any files from this phone in the folder you say because it doesn´t connect. |
