02-10-2010, 18:30 | #3016 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Cuba-Holguin
Member: 256260 Status: Offline Thanks Meter: 726 | Connecting Phone..Wait... Phone Imei : 353249-02-367856-4 Phone S/W : T229UVHC4 Phone H/W : REV0.100 Network : 00101 Net Code : #7465625*638*08981950# Sub Code : #7465625*782*00000000# SP Code : #7465625*77*00000000# CP Code : #7465625*27*00000000# UnFreeze Code : 20361480 Phone Code : 00000000 Codes Readed Ok... Connecting Phone..Wait... Phone Model : T229 Unlocking Phone...Wait... ERROR...Phone Not Unlocked... Alc C701x read codes and flash-unlock 100%ok..GOOOOD Connecting ... Flash ID.: 017E3022 , AMD 16 Mb. Firmware Ver. : 18F Phone Type : C701X-2BRGES1 Operator/Country : ORANGE / SPAIN Language : EN ES GAL BAS CAT Phone IMEI : 353205-01-688085-6 Backup File Saved.. Phone Connected Ok.. Nck Code : 2026125125 Spck Code : 2795206387 Insert Not supported Sim In The Phone Power ON Type You Code in Keyboard Press OK Key Calculated Codes...OK... Phone Disconnected ... Connecting ... Flash ID.: 017E3022 , AMD 16 Mb. Firmware Ver. : 18F Phone Type : C701X-2BRGES1 Operator/Country : ORANGE / SPAIN Language : EN ES GAL BAS CAT Phone IMEI : 353205-01-688085-6 Phone Connected Ok.. Changing Speed Up 921600 Bps... Please Wait... Writing Firmware ... Please Wait... Finishing Writing... Please Wait... Formating... Can take about 60/120 seconds Writing Firmware Ok... Now please Wait 15/20 seconds... Until phone Power On completely... Phone Disconnected ... KP170 direct unlock 100%Ok... Please Wait..Sending Boot ... Flash ID.: 017E3C00 , AMD 32 Mb. IMEI : 357042-02-211289-1 Phone S/W : KP170_AT_V10c Phone Connected OK.... Please Wait..Unlocking ... Some phones SouthAmerican after unlock phone still locked. You must flash phone using any Firmware in polar support. After this, repeat unlock process and phone will be unlocked Phone Unlocked OK.... Enter 2945#*# without a sim inside and select 'Fact. Reset'. TM150 unlock 100%ok.. ... DIAG MODE...OK ... For finish unlock you must do this STEP by STEP. Check phone battery, if is very low phone can be damaged. Press key 1 and will appears the MENU Enter 99 and press the right top key Enter 3 and press the right top key Enter 1 and wait few seconds, format area will be erased And finally press 3 times the right top key (phone will PowerOff) Now, your phone is unlocked |
The Following 5 Users Say Thank You to Yaio For This Useful Post: |
02-10-2010, 22:33 | #3017 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: SPAIN
Member: 532853 Status: Offline Thanks Meter: 610 | vod 541 unlocked ok. Quote:
The Following 4 Users Say Thank You to mamepap For This Useful Post: |
02-11-2010, 04:30 | #3018 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Kanada
Member: 737720 Status: Offline Thanks Meter: 1,421 | Sucessfull unlocked t456 Sucessfull unlocked t456 COUNTRY:CANADA NETWORK:ROGER MODEL:SUMSUNG T456 Unlocking Phone..Wait... Phone Is Unlocked Ok... If you phone is not Unlocked... Please Select E250V model Make Read Codes |
The Following 4 Users Say Thank You to jawi For This Useful Post: |
02-11-2010, 04:33 | #3019 (permalink) |
Member: 737720 Status: Offline Thanks Meter: 1,421 | Sucessfull unlocked Sucessfull unlocked LG CG225 COUNTRY:USA NETWORK: T-MOBIL MODEL:LG CG225 Please Wait..Sending Boot ... Flash ID.: 017E2100 , AMD 16 Mb. IMEI : 010902-00-203250-1 Phone S/W : G4050_SWVer_ Phone Connected OK.... Please Wait..Unlocking ... Some phones SouthAmerican after unlock phone still locked. You must flash phone using any Firmware in polar support. After this, repeat unlock process and phone will be unlocked Phone Unlocked OK.... Enter 2945#*# without a sim inside and select 'Fact. Reset'. |
The Following 3 Users Say Thank You to jawi For This Useful Post: |
02-11-2010, 04:35 | #3020 (permalink) |
Member: 737720 Status: Offline Thanks Meter: 1,421 | Sucessfull unlocked Sucessfull unlocked LG CG225 NETWORK:T-MOBIL COUNTRY:USA MODEL: LG CG225 Please Wait..Sending Boot ... Flash ID.: 017E2100 , AMD 16 Mb. IMEI : 011081-00-914004-4 Phone S/W : G4050_SWVer_ Phone Connected OK.... Please Wait..Unlocking ... Some phones SouthAmerican after unlock phone still locked. You must flash phone using any Firmware in polar support. After this, repeat unlock process and phone will be unlocked Phone Unlocked OK.... Enter 2945#*# without a sim inside and select 'Fact. Reset'. |
02-11-2010, 04:37 | #3021 (permalink) |
Member: 737720 Status: Offline Thanks Meter: 1,421 | Sucessfull unlocked BLACKBERRY Sucessfull unlocked BLACKBERRY 8100 MODEL: 8100 COUNTRY:CANADA NETWORK:FIDO Selected : Blackberry 8100 Pearl Reading Data...Please Wait... BGUID : D9BE6524A5F5047DB5866813ACF3277892A7A30A BPIN : 24894063 IMEI : 355085-02-651054-7 MFI-12511-014 MEP-06814-004 VSM-09712-002 SFI-12484-018 APP-13078-006 PRD-11929-011 Device connected OK... Contacting With Server...Wait... Credits Consumed : 0 NCK Code.........: 6399843004140098 ..(MEP2) Subset Code.....: 7977218123502140 ..(MEP3) Provider Code...: 3078998307829323 ..(MEP4) Corporate Code.: 3100641738624541 ..(MEP5) SIM Code..........: 4271438881937991 ..(MEP1) Log Saved... Unlock Code Readed OK... |
02-11-2010, 08:49 | #3022 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Blackberry 8520 Selected : Blackberry 8520 Reading Data...Please Wait... BGUID : 529B073BCB8EB8F175091140FE4C1A35455DB1CE BPIN : 2147CA55 IMEI : 358472-03-294514-8 MEP-09292-004 MEP-09292-004 VSM-26918-002 SFI-24398-027 APP-26112-008 PRD-22578-032 Device connected OK... Contacting With Server...Wait... Credits Consumed : 0 NCK Code.........: 6620227217558822 ..(MEP2) Subset Code.....: 8709279222356309 ..(MEP3) Provider Code...: 7242140748337622 ..(MEP4) Corporate Code.: 3587126679059421 ..(MEP5) SIM Code..........: 7903541532088864 ..(MEP1) Log Saved... Unlock Code Readed OK... |
The Following 3 Users Say Thank You to Amir-SkillZ For This Useful Post: |
02-11-2010, 08:51 | #3023 (permalink) |
No Life Poster Join Date: May 2008 Location: Sri Lanka , Kandy Age: 34
Member: 763865 Status: Offline Sonork: Cvlvertcharges Thanks Meter: 123 | LG KS360 Successful unlock by code polar box LG KS360 Successful unlock by code polar box thanks to polar team Please Wait..Sending Boot ... Phone type LG-KS-360 IMEI : 352074-03-193XXXX-X Phone Connected OK.... Reading SpLock zone...Please Wait......OK NCK Code : 75797221 Power On Phone with original simcard Type 2945#*71001# Go to Menu -> Setting -> Security -> SimLock Enter Nck code. Phone will be unlocked Phone Unlocked OK... |
The Following 4 Users Say Thank You to a.w.m.wafaz For This Useful Post: |
02-11-2010, 18:53 | #3026 (permalink) |
Member: 256260 Status: Offline Thanks Meter: 726 | B100 Read codes and unlock 100% ok Searching Phone Please Wait ... Phone S/W Version: B100BMHF4 Phone Imei: 353604-02-782242-0 Reading Codes Please Wait... Phone Codes... McK : 749185782 ScK : 1282680010 PcK : 1282680010 SpcK : 1282680010 NcK : 1282680010 Codes Readed Ok... Searching Phone Please Wait ... Phone S/W Version: B100BMHF4 Phone Imei: 353604-02-782242-0 Unlocking Please Wait... Phone Is Unlocked Ok... Huawei U1211 read codes unlock 100% ok... Connecting ... Waiting Flash Mode ... Sending Loader... Phone IMEI : 352644-02-036713-1 Reading SpLock Zone... Network : 734-02 Resetting Code Counter... Calculating Codes.... NCK : 4293313436497225 Rebooting Phone...Wait... Phone NCK Readed OK... Insert Not supported Sim In The Phone Power ON Press NCK Button Type You Code in Keyboard Press OK Button Connecting ... Waiting Flash Mode ... Sending Loader... Phone IMEI : 352644-02-036713-1 Reading SpLock Zone... Network : 734-02 Resetting Code Counter... Unlocking.... Rebooting Phone...Wait... Phone Unlocked OK... |
The Following 3 Users Say Thank You to Yaio For This Useful Post: |
02-12-2010, 02:26 | #3027 (permalink) |
Freak Poster Join Date: May 2009 Location: rumania
Member: 1025102 Status: Offline Thanks Meter: 74 | zet-g x761 : Polar Service Software :: ======================= ZTE X761 Selected - Phone Status OFF - Cable Not Connected to phone - Use Zte X760 Rj45 Datacable Cable Phone Imei : 35787 NCK Code : 688756660464 SPCK Code : 138358880732 Codes Calculated OK... |
02-12-2010, 02:32 | #3028 (permalink) |
Member: 1025102 Status: Offline Thanks Meter: 74 | lg-kp501 and polar Phone type LG-KP-501 IMEI : 35------------- Phone Connected OK.... Reading SpLock zone...Please Wait......OK NCK Code : 32377608 Power On Phone with original simcard Type 2945#*71001# Go to Menu -> Setting -> Security -> SimLock Enter Nck code. Phone will be unlocked Phone Unlocked OK... |
02-12-2010, 04:13 | #3029 (permalink) |
Member: 737720 Status: Offline Thanks Meter: 1,421 | Sucessfull unlocked Sucessfull unlocked T539 NETWORK:T-MOBIL COUNTRY:USA MODEL: SUMSUNG T-539 Connecting....Phone Phone S/W Version: 539UVHA1 Phone Imei: 355812-01-230572-7 Unlocking Please Wait... Phone Unlocked OK.... |
02-12-2010, 08:10 | #3030 (permalink) |
Member: 91045 Status: Offline Thanks Meter: 8,696 | 9500 Storm Selected : Blackberry 9500 Storm Reading Data...Please Wait... BGUID : 13C6B0AEA29F80D3FF746A01DD2B75C20ECB6F0B BPIN : 20C9A29B IMEI : 359484-02-081510-9 MEP-06814-004 MEP-06814-004 VSM-21360-001 SFI-21937-013 APP-22951-009 PRD-17491-002 Device connected OK... Contacting With Server...Wait... Credits Consumed : 0 NCK Code.........: 1985534170390944 ..(MEP2) Subset Code.....: 4707263140677196 ..(MEP3) Provider Code...: 5834727540321770 ..(MEP4) Corporate Code.: 7472108618554420 ..(MEP5) SIM Code..........: 0445315490422335 ..(MEP1) Log Saved... Unlock Code Readed OK... |
