08-13-2008, 12:24 | #46 (permalink) |
No Life Poster Join Date: Feb 2008 Location: SPAIN
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | Lg KG800 unlock ok. Flash ID.: 984A0001 , Toshiba 16 Mb. IMEI : 35****-**-******-* Phone S/W : KG800_P64FL_V10c Operator : 208-01 , France Telecom, France Phone Connected OK.... Please Wait..Unlocking ... Some phones SouthAmerican after unlock phone still locked. You must flash phone using any Firmware in polar support. After this, repeat unlock process and phone will be unlocked Phone Unlocked OK.... Enter 2945#*# without a sim inside and select 'Fact. Reset'. Br. ROTELCAM |
The Following 4 Users Say Thank You to rotelcam For This Useful Post: |
08-14-2008, 11:46 | #47 (permalink) |
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | Lg kp202 unlock ok. Use box lg7050rj45cable Please Wait..Sending Boot ... Flash ID.: 017E3C00 , AMD 32 Mb. IMEI : 35****-**-******-* Phone S/W : Unknow Phone Connected OK.... Please Wait..Unlocking ... Some phones SouthAmerican after unlock phone still locked. You must flash phone using any Firmware in polar support. After this, repeat unlock process and phone will be unlocked Phone Unlocked OK.... Enter 2945#*# without a sim inside and select 'Fact. Reset'. Br. .ROTELCAM. |
08-14-2008, 14:03 | #48 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | SkyZen EZ800 locked to Telcel - Mexico unlocked Ok with PolarBox2. I'm very happy because the polar has full support for the EZ700 and EZ800 Skyzen models, especially those of the company Telcel, which still packs great as the Infinity-Box should work more in the full solution for the company Telcel. Please, my intention is not to compare that cash is better and which not, both are excellent tools. Only in this case that undoubtedly makes Polar models Telcel Ok Here prtscrn: Br. elcapitel |
The Following 5 Users Say Thank You to elcapitel For This Useful Post: |
08-16-2008, 11:55 | #49 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | Alcatel E805 unlock ok Alcatel E805 unlock ok br <= The_Gorr => |
The Following 3 Users Say Thank You to The_Gorr For This Useful Post: |
08-16-2008, 15:53 | #50 (permalink) |
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | Lg Kp100 unlock ok with tricks. When first read codes and cant enter but require the sim fone was locked to for enter configuration. After enter code and press the gree key, fone is still locked. Flash ID.: 01001A01 , Spansion 4 Mb. Phone S/W : ************XUnknow IMEI : 359961-01-155707-1 Phone Connected OK.... Reading NCK.. NCK Code: 15601323 Insert Not supported Sim In The Phone After type You Code in Keyboard Press Calling Key Green Or Insert supported simcard and power on Enter this secuence 2945#*20001# Enter configuration -> security -> simlock and enter code Phone Disconnected.. If u dont have test card or original sim which fone was locked to. Do this., Make factory reset without sim and put not accepted sim in fone and do eeprom repair. fone is now unlock. Flash ID.: 01001A01 , Spansion 4 Mb. Phone S/W : ************XUnknow IMEI : 359961-01-155707-1 Phone Connected OK.... Please Wait..Unlocking ... Reading Eeprom Zone.... Eeprom Backup Saved... Writing Eeprom Zone... Eeprom Repaired Ok... Remove and put again Battery Press Power On in Phone 15/20 seconds Br. .ROTELCAM. |
08-16-2008, 17:01 | #51 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | samsung D500E unlock OK samsung D500E unlock OK br <= The_Gorr => |
The Following 2 Users Say Thank You to The_Gorr For This Useful Post: |
08-18-2008, 18:57 | #52 (permalink) |
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | Samsung C170 unlock ok. Searching Phone Please Wait ... Phone S/W Version: C170BGGF2 Phone Imei: 35****-**-******-* Unlocking Please Wait... Phone Unlocked OK.... Br. .ROTELCAM. |
The Following 3 Users Say Thank You to rotelcam For This Useful Post: |
08-19-2008, 11:16 | #53 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | E221 unlocked OK E221 unlocked OK br <= The_Gorr => |
08-19-2008, 11:44 | #54 (permalink) |
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | Sharp GX17/GX29 unlock ok. Use NEC N8 usb cable. download and install driver from support area. DIAG MODE...OK ... For finish unlock you must do this STEP by STEP. Check phone battery, if is very low phone can be damaged. Press key 1 and will appears the MENU Enter 99 and press the right top key Enter 3 and press the right top key Enter 1 and wait few seconds, format area will be erased And finally press 3 times the right top key (phone will PowerOff) Now, your phone is unlocked .ROTELCAM. |
08-20-2008, 09:34 | #55 (permalink) |
Junior Member Join Date: Jul 2005 Age: 39
Member: 165091 Status: Offline Thanks Meter: 7 | success unlock sagem x6-2 ROM Version. : 0411 Hash Key. : 275FAD4F8914B181 8C8853F8AFD1A3C4 Sending Certificate......OK Sending First Boot......OK Sending Second Boot......OK Wait Response from Phone......OK Reading Data...Can take 30/120 Secs...Wait......OK Connecting Server... - Credits....: 9 - Your codes: 0432084111 and 1493243855 - Credits Now : 8 - Log Saved... Phone Readed OK... |
The Following 5 Users Say Thank You to khalig For This Useful Post: |
08-20-2008, 14:36 | #56 (permalink) |
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | C7*** repairs ok. Incomplete boot/imei repair/on and off/ insufficient service/No network http:///vbb/showthread.php?t=582163 Br. |
08-21-2008, 20:54 | #58 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | SonyEricsson J110a 100% unlocked Ok br elcapitel |
The Following 6 Users Say Thank You to elcapitel For This Useful Post: |
08-22-2008, 16:19 | #59 (permalink) |
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | LG L600v unlock ok. Phone work 100% ok. emei ok. full network. Booting Phone...Wait.. Phone Type : L600V Phone S/W : M6250D-V10d-NOV-16-2006-V Phone Date : Feb 01 2007 Phone Imei : 35****-**-******-* Flash Type : toshiba_ty90009800aogg Phone Connected OK.... Please Wait..Reading ... Backup File Saved Ok... Please Wait..Writing ... Phone Unlocked OK.... Enter 63342425#*# without a sim inside and select 'Fact. Reset'. Br. .ROTELCAM. |
08-22-2008, 16:39 | #60 (permalink) |
Member: 698210 Status: Offline Sonork: 100.1578921 Thanks Meter: 3,591 | Philips 535 read codes/unlock ok. Phone Data H/W Version : 0114010701020000 S/W Version CT5358, OTP = 0048 IMEI : 35****-**-******-* Phone Codes ...... NCK : 83810984** STAT : Locked NSCK : ********** STAT : Unlocked SPCK : ********** STAT : Unlocked CCK : ********** STAT : Unlocked PCK : ********** STAT : Unlocked Codes Readed Ok.......... Insert Not supported Sim and Power On ... After type You Code in Keyboard ... |
