04-29-2009, 07:30 | #781 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | kp100 unlocked.... Phone S/W : KP100_04_FL_49_V10a IMEI : 355882-02-869970-2 Phone Connected OK.... Please Wait..Unlocking ... Reading Simlock Zone.... Simlock Backup Saved... Writing Simlock Zone.... Some phones SouthAmerican after unlock phone still locked. You must flash phone using any Firmware in polar support. After this, repeat unlock process and phone will be unlocked Insert Not supported Sim In The Phone After type 42413173 in Keyboard Press Calling Key Green how: :: Polar Service Software :: ======================= Selected Lg KP-100 ======================= - Phone Status OFF - Use LG Kg 320 / Kg 800 Datacable |
The Following User Says Thank You to FullFLASHgSMPH For This Useful Post: |
04-29-2009, 13:32 | #782 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | SAGEM MY150X UNLOCK OK! WITH PB2 Flash ID.: 0100C422 , AMD 2 Mb. Phone S/W : EAI_IJ_240708_1602 IMEI : 355727-01-178836-0 Phone Connected OK.... Reading Simlock Zone.... Simlock Backup Saved... Writing Simlock Zone.... Phone is Unlocked Ok... |
The Following 2 Users Say Thank You to fokal2008 For This Useful Post: |
04-29-2009, 13:42 | #783 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | HUAWEI T156 OK WITH PB2 Flash ID.: 0100C422 , AMD 2 Mb. Phone S/W : Sep_23_2008 Phone ID : 5DF527946274D13E Phone Connected OK.... Please Wait..Unlocking ... Reading Simlock Zone.... Simlock Backup Saved... Writing Simlock Zone.... Phone is Unlocked Ok... |
04-30-2009, 05:56 | #785 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | samsung Phone Model : GT-S7330 phonelocked evev no sim inside Connecting ... Phone Model : GT-S7330 Phone S/W : S7330JBH Phone IMEI : 354522-02-093090-0 Contacting With Server...Wait... Credits Consumed : 0 Phone Codes... Net Code : #7465625*638*00000000# Sub Code : #7465625*782*00000000# SP Code : #7465625*77*00000000# CP Code : #7465625*27*00000000# SIM Code: #7465625*746*12369874# Activa Code: #7465625*228*12369874# UnFreeze Code : 85305814 This Phone Is NOT LOCKED... Codes Readed OK... :: Polar Service Software :: ======================= Selected Samsung S7330 ======================= - Phone Status ON - Use Hybrid (Rj45 + Usb) V804 Datacable Instructions... - Power On phone Without Simcard - Enter Sequence *#726872# - Download / Install Drivers - Press Read Codes If UserCode is activated, you c'ant Read Codes Please Make Read PLock and disable it About Change Driver Mode by Some Models... - By put in Qualcom Mode... *#782872# - By put in Samsung Mode... *#726872# - Samsung Mode need Hybrid Cable Usb + Rj45 - Qualcom Mode need Only Cable Usb - You need Download appropiate Driver from Support |
The Following 3 Users Say Thank You to FullFLASHgSMPH For This Useful Post: |
04-30-2009, 11:46 | #786 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Connecting ... Sending Loader... Phone Model : SGH-J750 Phone IMEI : 354735-01-102666-6 NOR Flash : KAP 29NWN00M - NOR MLC NAND Flash : MCP-KAP29VN00M One NAND Phone Codes... Network : 515-02 Net Code : #7465625*638*15960638# Sub Code : #7465625*782*00000000# SP Code : #7465625*77*00000000# CP Code : #7465625*27*12369874# SIM Code: #7465625*746*00000000# Activa Code: #7465625*228*12369874# Full Reset : *2767*3855# Phone Passwd Reset *2767*8451# UnFreeze Code : 14789632 Codes Readed OK... Restarting Phone... note:use e210 usb only :: Polar Service Software :: ======================= Selected Samsung J750 ======================= - Phone Status OFF - Install correct drivers (in support) - Quit battery from phone (not use it) - Press Read Codes - Connect phone to cable and wait - Use E210 USB (only USB) Datacable |
04-30-2009, 19:18 | #787 (permalink) |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | :: alctel c630 unlocked ok:: c630 done polar mother of alcatel |
The Following 4 Users Say Thank You to toutou_gsm For This Useful Post: |
04-30-2009, 23:01 | #788 (permalink) |
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | ::j400 done with usb cable only:: j400 unlocked with usb cable only no need combo cable polar father's samsungs |
05-01-2009, 02:28 | #789 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | moto w370 HOW: :: Polar Service Software :: ======================= Selected Motorola W-370 ======================= - Phone Status OFF - Use Motorola T-191 Datacable Full Repair Phone : - Flash phone with fullflash from PB2 Support - Make Repair function - Phone will be unlocked and repaired |
05-01-2009, 12:45 | #790 (permalink) | |
No Life Poster Join Date: May 2009 Location: destination SL3 brute force
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | M600 Model: M600 cable: E210 Quote:
The Following 3 Users Say Thank You to POLARBOX_TEAM For This Useful Post: |
05-01-2009, 18:23 | #791 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 523957 Status: Offline Thanks Meter: 118 | zv10 unlock success zv10 (new algo) unlock success using polar Phone Connected... Phone New Algorithm Detected.. Reading Codes.. Wait... MCK Code : 3058247 NCK Code : 40539581 SPCK Code : 00000000 Operator Code : 208-106 Codes Readed Ok... Test Active Code With * # 7465625 # Insert incorrect sim and type code Last edited by The_Gorr; 05-01-2009 at 18:56. |
The Following 3 Users Say Thank You to redouane2007 For This Useful Post: |
05-01-2009, 20:31 | #793 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 533032 Status: Offline Thanks Meter: 13 | f480v ok Connecting ... Phone Model : SGH-F480V Phone Network : 208 10 Phone S/W : F480AEHE2 Phone IMEI : 353670-02-173235-2 Contacting With Server...Wait... Credits Consumed : 0 Phone Codes... Net Code : #7465625*638*02802596# Sub Code : #7465625*782*00000000# SP Code : #7465625*77*00000000# CP Code : #7465625*27*00000000# SIM Code: #7465625*746*12369874# Activa Code: #7465625*228*-# oÌÿŒ_# UnFreeze Code : 52837159 Codes Readed OK... |
The Following 3 Users Say Thank You to mobadi For This Useful Post: |
05-02-2009, 10:05 | #794 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 308433 Status: Offline Thanks Meter: 97 | Connecting Phone..Wait.. Flash ID.: 017E0A01 , AMD 4 Mb. Phone Type : E256 Phone S/W Version : E256X-2ATBHU1 Operator / Country: T-MOBILE / HUNGARY Languages : GER HUN FIN FRE Phone IMEI : 356320-00-133****** Phone Conected Ok.. Unlocking Phone ... Reading SpLock Zone... Reading SpLock...Ok Backup SpLock File Saved.. Writing SpLock Zone... Unlocking DONE... |
The Following 2 Users Say Thank You to qvadis For This Useful Post: |
05-02-2009, 10:08 | #795 (permalink) |
Member: 308433 Status: Offline Thanks Meter: 97 | Connecting Phone..Wait.. Flash ID.: 017E0A01 , AMD 4 Mb. Phone Type : E256 Phone S/W Version : E256X-2ATBHU1 Operator / Country: T-MOBILE / HUNGARY Languages : GER HUN FIN FRE Phone IMEI : 356320-00-133**8-* Phone Conected Ok.. Unlocking Phone ... Reading SpLock Zone... Reading SpLock...Ok Backup SpLock File Saved.. Writing SpLock Zone... Unlocking DONE... |
