Vodafone 875 unlock (Vodafone Smart mini) [SOLVED] dont find in polar list,can you make test polar team:p v875-2avdes1 355963050767185 second one. v875-2avdes1 355963050773407 |
not supported yet :) but u can try to connect it via cable selecting some alcatel models then press read codes test and post result :) Br |
not got conected,tried selecting many models of alcatel.waiting for response or conect error. |
please try to connect it as OT-875T, also try to calculate code manually and test, i think can work too test selecting ZTE V875 Br |
solved thanks polar team.thanks the gorr:). |
please explain how :) Br |
Phone Selected : Alc. OT-V975 Phone ID : V875-2AVDES1 Phone Imei : 355963050773407 Nck Code : 07265164 Spck Code : 13891925 Nsck Code : 14124696 Cpck Code : 13645824 Cck Code : 05674612 Pck Code : 09281545 Insert Not supported Sim In The Phone Power ON Type You Code in Keyboard Press OK Key Calculated Codes...OK... ---- IMPORTANT ---- If phone not accept NCK, sometimes must be resetted A) Press VOLUME UP + POWER ON (at same time) B) Press KEY # + POWER ON (at same time) If the phone requests unlock code Insert the original sim Power ON Type ###765*08# Select Network Unlock and enter Nck |
Regards |
Hi, friend. I got 2 pcs of phone-Vodafone 875 unlock, i used polar box calculate the nck code, but it said wrong code when i entered. anyone unlock ths phone successful? can you help me? best regards, TONY8118 |
use cable for read codes Br |
And the solution was calculate by Vodafone 875 and the code OK. Regards |
