Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3
Old 01-21-2015, 18:47   #1 (permalink)
Member: 1594731
Thanks Meter: 8
wrong alcatel codes, pls refund [SOLVED]
pls refund credits, calculated code is wrong. I had to purchase from another unlock server and their code worked correctly.
my serial no. A0001E29700
Engine Compilation Build : 358
Contacting With Server...Wait...
Consumed 4 , Credits left: 24
Calculation Data
Phone Selected : Alc. OT-7041
Phone ID : 7041X-2AYGES1
Phone Imei : 863859021681148
Nck Code : 0182277372
Nsck Code : 1734560698
Spck Code : 1544344954
Cpck Code : 4160169921
Cck Code : 0136295874
Pck Code : 0439091926
Insert Not supported Sim In The Phone
Power ON
Type You Code in Keyboard
Press OK Key
Calculated Codes...OK...
---- IMPORTANT ----
If phone not accept NCK, sometimes must be resetted
A) Press VOLUME UP + POWER ON (at same time)
B) Press KEY # + POWER ON (at same time)
C) Press VOLUME DOWN + POWER ON, select CLEAR EMMC and press HOME
If the phone requests unlock code
Insert the original sim
Power ON
Type ###765*08#
Select Network Unlock and enter Nck
Old 03-06-2015, 12:41   #2 (permalink)
Member: 1594731
Thanks Meter: 8
hello team,
it has been over 1 month and still no reply or solution from your side.
Old 03-06-2015, 12:54   #3 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Now all alcatel are free without credits then something change for better for users.
Old 03-08-2015, 13:04   #4 (permalink)
wendigo's Avatar
Member: 10286
Sonork: 100.90962
Thanks Meter: 4,353
Calculation Data
Power ON
Press OK Key
---- IMPORTANT ----
Power ON
Type ###765*08#
Hi friend,
Sorry for the inconvenience and delay, i added now the credits to your balance (+4 credits), please verify and tell me if all is correct.
With best regards,
\W3nd|g0
The Following User Says Thank You to wendigo For This Useful Post:
Page generated in 0.14479 seconds with 8 queries
