Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > KULANKENDI Server
Old 11-04-2008, 19:07   #1 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
W760i Flashing Problem
Hi. I've just downloaded the KulanKendi client v1.96. I've tried to flash a SonyEricsson W760i but seems to be unsupported:
With 2+5 pressed:
Hold 'C' or '@'-(PDA) or '2'-(W88x) or '2+5'(W760) or '6'(W350) key and plug DCU60 USB cable.
Phone Connected...
Detected: DB3150: A2 Series
Error: K
Wrong BOOT mode!Be sure that You hold 'C' or '2' or '6'(W350) or '2+5'(W760) or '@' Key.
With 5 only:
Phone Connected...
Phone IMEI: 00440107-453xxx-4
Error: Unsupported Certifiacte Color!: 0x02
Contact With Reseller.
Any help?
Thanks and best regards
Bypx
Old 11-05-2008, 03:41   #2 (permalink)
Member: 384655
Thanks Meter: 517
did U try "C" key ?
b.r.
With 2+5 pressed:
Phone Connected...
Error: K
With 5 only:
Phone Connected...
Any help?
Bypx
Old 11-06-2008, 03:08   #3 (permalink)
Member: 379553
looking at your imei and cert color, you have a prototype phone, just like me. mine is fu*$@d up. it is in a state of constant reboot, and SE won't repair (sent it in, they returned it saying i shouldn't have a prototype). anyways, mine has CID 49 Brown, which I guess you probably have too. If the KK guys can find a way to get yours to flash, then mine will probably be able to reflash too, and I can fix it.
hope that gives some insight.
Old 11-06-2008, 14:21   #4 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
It can't be a prototype, because is a branded phone from TIM Italy.
Old 11-06-2008, 14:24   #5 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
Originally Posted by KulanKendi View Post
did U try "C" key ?
b.r.
Hi, thank you for the reply.
"C" key can't be used on that phone, it goes to boot mode only with 5 or 2+5 pressed.
With sony ericsson update service the phone is recognized but there isn't a new firmware for TIM phones.
With Best Regards
Bypx
Old 11-07-2008, 10:18   #6 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
Please update your client, I've here this W760i to flash and I can't do anything.
Phone Connected...
Phone IMEI: 00440107-453xxx-x
Old 11-07-2008, 15:03   #7 (permalink)
total-gsm's Avatar
Member: 320325
Thanks Meter: 4
Did you unlock your phone or perform any operation using the Ultimate Unlocker from Cruiser?
I think your certificate has turned blue , also the IMEI is looking a bit weird.
Old 11-07-2008, 17:46   #8 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
The imei is original. About certificate color: I've never touched it with cruiser or any other sw.
Bypx
Old 12-02-2008, 18:57   #9 (permalink)
Member: 66340
Thanks Meter: 5
I get problem for flashing W760I,using SETOOL,I always hold "C" ,software doesnt run.I will try to hold 2+5 to try again.
Old 12-02-2008, 19:04   #10 (permalink)
Member: 384655
Thanks Meter: 517
because is not setool forum
b.r.
Old 12-03-2008, 16:28   #11 (permalink)
piracik's Avatar
Member: 133762
Thanks Meter: 242
its prototyoe read under battery - prototype not for sale
but maybe cid cross-fleshing could be a way
Old 02-14-2009, 17:33   #12 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
EDIT: New KK Forum: http://www.forum4gsm.com/forumdisplay.php?f=26
Is not a prototype for sure, maybe it was touched before.
How I can convert the certificate color?
se w760i charge problem dvdgsm Sony Ericsson Hardware Repair 2 02-01-2011 14:51
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 rafik2533 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-04-2010 20:38
Flashing Problem UniversalBox 6110 Nokia Flashing Problem No available Boot Loader Ravi Potdar Universalbox 1 05-29-2009 15:00
d780 flashing problem...after flashing ringer problem gsm st SWIFT Platform 2 03-22-2009 22:29
N3210 flash problem. flash id:FFFFFFF pali Nokia Hardware & Hardware Repair 7 05-26-2002 22:48
Page generated in 0.52541 seconds with 9 queries
