Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > KULANKENDI Server
Old 08-17-2007, 17:55   #1 (permalink)
Member: 77227
Thanks Meter: 26
how to repair K800i red blink cid49?
I have this K800i CID49, with red light blink problem... I search on forum about metod to repair it, but did not succed until now...
Could you please explain the correct way to repair it with KK?
Thanks to all.
Old 08-17-2007, 19:25   #2 (permalink)
fs_djmellisse's Avatar
Member: 65093
Sonork: 100.1580654
Thanks Meter: 48
i have a same problem .. after unlock my k800 with davinci succeffuly , the phone doesn'yt want to power up he red blinkin :s ..
i have try to repari it with KULANKENDI Server .. but not result
Old 08-17-2007, 21:02   #3 (permalink)
Member: 384655
Thanks Meter: 517
use COM cable and set communication to RS232(select com port).
click EROM Update and click FLASH, plug cable to phone, if communication will not start then push power on button.
If U have EROM damaged then U will fix it, if U have security area damaged then U need to recalculate it(davinci etc)
b.r.
Thanks to all.
Old 08-17-2007, 21:04   #4 (permalink)
Member: 384655
Thanks Meter: 517
U can try EROM Update
If U have GDFS security blocks damaged then only again davinci unlock can help.
b.r.
Old 08-17-2007, 21:29   #5 (permalink)
Member: 77227
Thanks Meter: 26
Thank you for your reply. I tried as you said and get this:
Connect and Power ON phone.
Phone Connected...
Detected: DB2020 Series
Trying set speed on: 921600
Flash ID: 0x2019 - Supported
EROM CID Detected: 49
Status:3
EROM Update Ok!
All Done! - Time:00:00:03
But phone still dead...
Should I try to flash + finalization?
b.r.
Old 08-18-2007, 23:41   #6 (permalink)
Member: 541419
yes i got the same i do update erom with kulan kendi but nothing (
Old 08-19-2007, 11:45   #7 (permalink)
Registered User
the new's Avatar
Member: 36653
Thanks Meter: 336
lol kulankendi server do not only repaire erom but updaye it to last version of erom and if you like you can flash the phone and update erom to cid52 mybe the phone will be alive egain
Old 08-19-2007, 12:34   #8 (permalink)
DZStorm's Avatar
Member: 160204
Sonork: 100.113150
Thanks Meter: 2,843
Anti-Spaming Warning! Reaction will be more surious next time .
Old 08-19-2007, 12:36   #9 (permalink)
DZStorm's Avatar
Member: 160204
Sonork: 100.113150
Thanks Meter: 2,843
@et.com
Finalization is necessary !
Old 08-19-2007, 18:39   #10 (permalink)
SekingServer's Avatar
Member: 565161
Sonork: 100.1585588
Thanks Meter: 44
you K800 now is good ? m8
Old 08-20-2007, 01:45   #11 (permalink)
Registered User
the new's Avatar
Member: 36653
Thanks Meter: 336
Angry
what I have do ?????? I write that server update erom not like cruiser that repaire old erom not update it to last version
next time d,ont do what you d,ont know and you d,ont understand
I am traying to help all user to work with this good server (see all my old post ) I am more than you for supporting this good product
Old 08-20-2007, 03:30   #12 (permalink)
Member: 384655
Thanks Meter: 517
@et.com
if Phone is still RED Blinking then U have damaged security blocks and U need buy again DAVINCI logs.
If phone is not RED blinking but just DEAD then flash it
@boskon
I repeat again. RED blinking phone is NOT ONLY damaged EROM. It can be also hardware Fault,deleted,damaged security block(need pay xx euro to fix)...
b.r.
Phone Connected...
Status:3
EROM Update Ok!
Old 08-20-2007, 03:34   #13 (permalink)
Member: 384655
Thanks Meter: 517
is about mixing solutions, nothing wrong but unexperienced users will kill more phone by test,test and again test, so if he asking help at KK subforum then we try to help to him as product supporters. When that user(s) will damage more phone he can blame us after. So we preffer be responsible for our product only.
I hope U understand me
b.r.
Old 08-20-2007, 09:41   #14 (permalink)
Member: 77227
Thanks Meter: 26
Thanks to all...
First, cruiser is not solution... The problem of this phone was caused by a friend on cruiser... and he could not repair it until now, so I'm trying to repair it myself.
to KK:
You said the only way to repair my phone is to use Davinci logs, so it's no use to try 'update to CID52+Finalisation' on KK?
Thanks and regards, Tozito.
Old 08-20-2007, 10:50   #15 (permalink)
Member: 65093
Sonork: 100.1580654
Thanks Meter: 48
b.r.
Thank you for answering , i'll buy one log Davinci unlock , and i'll try to reUnlock it
Thank you again for your help !!
how to repair sonyericso red blink & gdfs in ub zeeshan tayyab Universalbox 3 08-30-2009 19:16
How to repair gdfs, red blink and how to upgrade cid with ub in sony ericsson phones svchost Universalbox 1 04-29-2009 16:00
HOW to Repair W580i red lights blink ikkks Cruiser Suite 8 01-20-2009 14:58
How to Repair K750i with Ps Cid49 Brown and Sc Cid36 Brown Roni1976 Cruiser Suite 19 11-28-2006 08:05
how to repair erom in k750 cid49? cevil Cruiser Suite 9 07-26-2006 11:05
Page generated in 0.38904 seconds with 10 queries
