07-02-2007, 16:31 | #1 (permalink) | |
Junior Member Join Date: Mar 2007 Location: Indonesia
Member: 473137 Status: Offline Thanks Meter: 0 | Manual Unlock SE DB2020 CID49, 51 Using Original DCU-60 USB Cable *ONLY* For KKClient ver.1.62 or newer. First of all: This method is PATCH unlocking, it mean it will not unlock Your phone permanently. Any change firmware after unlocking with this way will lock back Your phone. So please think all steps before unlock phone eg. Flash first(change firmware or language) and after unlock. We DO NOT respond,back credits for wrong usage! Step 1: Download the KulanKendi Client from here: (about 2.3MB) http://gsminfo.home.pl/_ftp/guar/KK_Client/KKClient.exe And save to directory / folder like C:\KKClient\ Step 2: After download finished go to directory C:\KKClient\ and run the file: KKClient.exe The KKClient will create 4 sub-directory like below: C:\KKClient\ErrorLogs C:\KKClient\FlashFiles C:\KKClient\SFL_Files C:\KKClient\UserLogs Step 3: Download SPL files archives from: (about >110MB) http://gsminfo.home.pl/_ftp/guar/Data/SFL_Files.zip And save to C:\KKClient\SFL_Files After download finished, extract the ZIP file at the same folder. ATTENTION: Don't try to create another folder, just extract at the same folder. Step 4: Now connect the original DCU-60 USB cable (the USB cable that come with phone) and power on phone and install driver. The driver can download from here: (about 5KB) http://gsminfo.home.pl/_ftp/guar/Dat...SB_Drivers.zip Step 5: At the KKClient windows, click "Read Info" button. Turn off the phone, remove battery and put back again but DON'T turn on the phone. Hold the "C" button on the phone and plug the DCU-60 cable. Step 6: If the KKClient status windows says: "Firmware supported for patch unlocking" go to Step 8 BUT... if the KKClient popup the alert says: Quote:
WARNING!!! If KKClient status window says: "Firmware NOT supported for patch unlocking !!!" you should stop at there copy all the text at the status windows and email to KulanKendi support. Also... if KKClient says: "Warning!!! CID is not supported" you should DON'T go anywhere, just close KKClient and after a few days, maybe few weeks you can check at: http:///vbb/showthread.php?t=354542 to see there is a new version release of KKClient (current version is 1.62) that support CID42 unlock. EDITED by Kulankendi: or look there: http://gsminfo.home.pl/_ftp/guar/Data/SFL There are not zipped files what users report before as not supported and was uploaded when found there. Step 7: Unplug DCU-60 cable from the phone, remove battery and put it back again but DON'T turn on. Click "OK" to start EROM update process. Hold together "2" and "5" button on the phone and plug the DCU-60 cable. After update process finished continue to Step 8. Step 8: Unplug DCU-60 cable, remove battery and put it back again but DON'T turn on. Select "Simlock CID49, 51" and click "Flash Phone" button. Unlock begin, wait until the entire process finisihed, it may take around 50-60 second. Step 9: Congratulation... U're Done... The important step: Don't forget to buy KulanKendi Server Logs. Thanks to AllGsmUnlock and KulanKendi. Last edited by KulanKendi; 07-28-2007 at 22:18. Reason: Revision. | |
K800i Cid52 + Dcu-60 Usb Cable | arielm76 | Cruiser Suite | 2 | 12-18-2007 21:57 |
List of phones supported by DCU-60 USB cable needed | cimomario | Cruiser Suite | 4 | 08-16-2007 03:43 |
Manual Unlock SE DB2020 Ilustrated CID49, 51 CID49, 51 Using COM Cable *ONLY* | kikodog | KULANKENDI Server | 2 | 06-16-2007 14:53 |
@Lead: plans for supporting DCU-60 USB cable direct? | IndianL | Cruiser Suite | 2 | 06-24-2005 21:17 |
