01-30-2009, 03:41 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 356 | problems with LG new Sec (u250) Looking for phone... Error: Internal! > COM port routine > 3 trying to unlock LG U250 |
01-30-2009, 08:00 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | disable firewall check ur comport it lower than 20 uninstall drivers restart PC then install drivers use this drivers "LGUSBModemDriver_WHQL_ML_Ver_4.7.zip" http://forum.gsmhosting.com/vbb/show...1+port+routine BR UMER |
01-31-2009, 00:21 | #5 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 356 | ok,drivers at support, but, I tried with both ports higher and lower than 20, and did not succed, it is not a firewall issue, because I tried to Read Info, and software Suddenly replies the error, without attempting to make any network connection. I will try the driver you said I am using the other version 4.9 KOR, if after using these drivers it doesnt works then I think there is a software bug which should be fixed, 2 sets here, this is a fresh Windows OS install. |
01-31-2009, 00:46 | #6 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 356 | Solved OK ppl. I can confirm the issue is not a Firewall problem I installed the 3.7 Drivers and it is working now. I am not sure about com port number if needed tpo ve above or before 20, bnut I can confirm the 3.9 driver will not work. maybe this should be written at KK software for newcomers... Thanks to the guy of the driver TIP Connecting to server... Looking for phone... Phone detected. Phone Model: U250 Phone IMEI: 356385-01-xxxxxx-0 NAND Info: hynix_hyc0ueh0mf3p | 00AD:0076 | 20:200 | Revision: U250-MSM6245-V10a-MAY-19-2007-XX Brand info: U250FL-V10a-01-222-99-00-00-00-MAY-19-2007+0 Compiled date: May 19 200702:54:59May 19 200714:00:00U250 PhoneLock Code: 0000 Connecting to server... Phone and Version are supported. Reading simlock data... Connecting to server... Clearing SimLocks... Unlocked successfully! Restarting phone... All Done! - Time:00:01:00 |
Can Help Me With 8900 New Sec Code?... | jeffto | Phone Unlocking Codes & Maps | 1 | 01-08-2010 20:55 |
SMTi Ver,17.69 LG new Sec. 2009 already added . LG3G Autolern already added !!! | gsminfo | Service Products News & Updates | 0 | 10-21-2009 14:47 |
Update all version lg new sec. Others very easy:::WORKING STAY TUNED::: | budaw | PolarBox 3 | 1 | 06-23-2009 04:12 |
LG new sec.. activation | delta_uk1 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 12-19-2008 20:29 |
