Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > KULANKENDI Server
Old 05-30-2007, 02:22   #16 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.54 Update Information
Ver 1.54
- Flash Patch unlocking simlock for DB2020 CID49 and CID51 added.
- All options can works now by COM Port cable (FTDI Boxes etc).
- Fixed problem with COM Port speed select.
- Fixed bug with COM<>USB Selection what cause appl.crash.
- More speeds detection for COM Port (9600 kbps for ROM BOOT).
- Fixed problem with DB2020 USB detection on some computers.
- Decreased font size in main window(informations grown up).
- Back to NEW CDA Change Function,after test and investigation I discovered that all is ok problems is that some PDA NOT SHOW changed CDA in phone menu, so PLEASE always read CDA from phone by READ INFO button!
- Unlock DB2020 models are supported now by flash patch. It mean that phone flashed(MAIN) will have lock back. Only CID49,51 is supported and COM cables/boxes(for now). Instruction are in KKClient after select Simlock option(there will be link to instruction TXT file). For now Simlock will only work as alone option(without finalization or user code for example). Before unlock phone please read information by USB cable, KKClient will show that firmware is supported or not, after is safe to unlock by COM cable/Box. If KKClient will not support some firmwares please post it on forum or send to ICQ support number, I'll try to find and add it. This option is under test/work so soon can be more features like permanent unlock and usb cable...
b.r.
Old 06-05-2007, 16:35   #17 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.55 Update Information
Ver 1.55
- Faster Firmware list downloading(compression used).
- Added autodetection for "SFL_Files" subfolder placed in "SFL_File" folder and auto correct procedure.
- Timeout for PrgCXC waiting increased(it caused error for some sw version).
- Update EROM checking fixed for ver R3A022
Because firmware list what are stored on our server grown and grown, compression was used to faster refresh firmware list.
Many users report problem with "firmware not supported to patch unlocking..." problem because they didn't read short manual or made something wrong with SFL_Files and probably decompress files to subdirectory SFL_Files(created by WinZIP) in directory SFL_Files. KKClient version 1.55 will try to detect it and make self correction if it's possible, I hope will help...
Timeout value increased to wait for PrgCXC sw information - some users report ACK error before.
Phones with new EROM R3A022 was wrong detected and KKClient report that EROM is old and propose to update it and not allow to do any operation when it was canceled, now is fixed. I still not add R3A022 EROM Update because I'm not test it with patch unlocking yet. When all will be ok then I'll add new EROM Update code.
b.r.
Old 06-13-2007, 19:04   #18 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.56 Update Information
Ver 1.56
- Fixed problem with SFL files detection for CID cross flashed and only CID changed phones.
- Speeded up some variables downloaded by http protocol by changing server.
- DB2020 BROWN CID49 phones supported.
- Fixed problem for phones what was CID cross flashed by other services, for example OTP CID49 with Firmware R1JC002 or Firmware what normally not exists for that CID. Now KKClient will Support SFL Files without CID number. What it mean?less problems with "not supported for patch unlocking".
- Server changed for store some data for client, so now client should faster check for new version, less connection to server problems etc.
- One user report us that have phone(K810) with BROWN CID49, so KK need updated loaders, files will be uploaded soon...
b.r.
Old 06-17-2007, 06:55   #19 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.57 Update Information
Ver 1.57
- Fixed bug made in unlocking procedures during test USB unlocking(sorry for that).
- Fixed problem with finalization for Z710,W880 phones.
b.r.
Old 06-17-2007, 07:01   #20 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.58 Update Information
Ver 1.58
- New *.SLF2 files are needed for better efficiency(old ones will be autodeleted).
New SFL files reorganization for better efficiency.
It mean that ALL USERS must to download new "SFL_Files.zip" from support (or direct link:http://gsminfo.home.pl/_ftp/guar ) and decompress it to SFL_Files directory.
From version 1.58 SFL files will have extension *.sfl2 and only files with that extension will be acceptable. SFL_Files.zip contain all files what are available for now.
Ver 1.58 will self delete old *.sfl files, but if anyhow they are not deleted while first run then please delete them manually.
Attention: New SFL_Files.zip file will be available for download after 1h from time of posting this message.
b.r.
Old 06-20-2007, 04:08   #21 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.59 Update Information
Ver 1.59
- Unlocking by USB (DCU60) is supported now.We recommend to use this cable.
Finally possible to unlock phone by DCU60 Cable. Because there was some problems with boxes compatibility then please use USB cable for unlocking.
Unlocking by USB need to remove USB cable and plug back (without hold "C" key) when software will ask, rest operation is automatic.
Because USB allow to read information about phone then this time KK will NOT allow to kill phone when *.SFL2 file is not available.
Unlocking time is about 32-33 seconds.
b.r.
Old 06-20-2007, 20:38   #22 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.60-1.61 Update Information
Ver 1.60
- USB unlock temporary disabled coz was some bugs
Ver 1.61
- Enabled USB unlock
I test ver.1.61 with some persons and few PC, now all should works. Problem was on slow computers, so please use KK on possible fastest computers what U have.
After first part sw will ask to Remove Cable and Battery, put back battery and connect cable(with or without C key).
At this stage if any error happen then log is not discounted
I want to inform that I go to holidays and will not be available for 8-10 days
b.r.
Old 06-29-2007, 18:31   #23 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.62 Update Information
Ver 1.62
- Add message "not supported" for PDA phones while trying simlock for "non reading ppls"
- Language.ini version added to mainbar to inform about required translated
language.ini(if used).
Some users not see difference between DB2000,DB2010 and DB2020 and click,click,click without reading,so new checking was added to not allow to use simlock uption what will not work for PDA phones and take credit(null operation).
Now KKClient will show version of required Language.ini file (when some users use it), so user can know always if new Language.ini is available (we have Polish language for now).
b.r.
Old 07-29-2007, 00:52   #24 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.63 Update Information
Ver 1.63
- Added button "New SFL2" there will be uploaded all new found SFL2 files,so please check there sometimes.
- Added proxy settings(SOCKS4/5).
- Added pop-up window to wait for user action while unlocking(for some peoples last method didn't work correctly.
New button New SFL2, it will open webpage with all new SFL2 files what users report as missing so please check sometimes there for new files or if somone will report missing file and post log then there I'll upload missing SFL2 file.
As somone requested I add Proxy settings, it work with SOCKS4/5 proxy, users who not need it please not play with that settings, all who use proxy and need to use(internal network on proxy) will know how to use.
Bacause some users report me problem while unlocking:
Disconnect cable,remove battery and put back and connect cable.
Phone Connected...
Error: No response.Remove battery and put back
I add pop-up window what will wait for user action: "remove battery,put back and click OK button", now will work for every one
b.r.
Old 08-01-2007, 01:58   #25 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.64 Update Information
Ver 1.64
- Messed up Firmware list bug fixed(before show wrong files to download).
User inf5243 found a bug in Firmware list, what show wrong files to download(mixed CIDs etc.). Thanks for report it.
b.r.
Old 08-07-2007, 04:44   #26 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.65 Update Information
Ver 1.65
- NEW CREDIT COUNTING RULES! From now 3 operations per phone are allowed for 1 credit in 24h!!!.For more info read forum.
- Server communication protocol extended.
- Options color changed,from now RED color meaning = use credit(s).
- Firmware list bug finally fixed.
* From version 1.65 we start to count Credits with new rules. Now user can do 3 operations for same phone within 24hours, after 24h information will be deleted from server. Here are some examples how it works:
with 1 credit user can:
Example 1
- Flash phone with finalization
- Clear user code
- Unlock phone
Example 2
- Clear user code and Clear call timer
- Change CDA and Reset Flip Counter
- Unlock phone
Example 3
- Update CID
- Clear user code
Example 4
- Flash phone with finalization and do any mistake
- Repeat flashing with correct files
- unlock phone or again flash or do other operation what cost credit
PDA Example
- Change CDA do mistake
- Change keyboard variant and CDA
Every after operation server will shown how many Free operations left for actual phone, sample:
..... cutted log
Sending Loaders...
Please Wait, GDFS Process Started...
Connecting to server...
DO NOT interrupt,please wait...
Free operation left: 1
User code set to 0000
All Done! - Time:00:00:25
HALF-ACTIVE account - What is this?
If user had 1 credit or last credit and will use it for operation then normally account have 0 credits, in this case account will be "half-active", so it mean that server will allow to do rest 2 operations within 24hours - after account will be closed.
Remeber: User have 24hours to use 3 operations for EVERY phone, countdown will start when first operation will be executed. For every phone mean: Phone X start at 6:00 AM - countdown start for this phone, Phone Y start at 12:50 PM - countdown start for this phone..
PLEASE READ IT CAREFULLY till undertand new rules. We will DO NOT BACK that "free" credits.
* From version 1.65 all options what need to communicate with server and take credit are on RED color.
* Finally firmware bug list fixed
B.r.
Old 08-17-2007, 15:12   #27 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.66-1.67 Update Information
Ver 1.67
- Change bands option added for K790/K800 - 850Mhz<>900Mhz(please note: This will NOT fix network problems after bad flashed K790/K800!).
- W830 finalization problem fixed.
- Fixed ">DE /tpa" error.
Change band option is not tested in 100%,anyway those users who have 850Mhz band operators can check it, for sure it change band from 900/1800/1900Mhz to 850/1800/1900Mhz but we are not sure if need or not hardware modifications(filters).This option works only in K790 and K800.
Ver 1.66
- some bug fixed.
b.r.
Old 09-20-2007, 05:06   #28 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.68 Update Information
Ver 1.68
- No more ZIP with SFL2 files.Now all files are as separated(old/new) at: http://gsminfo.home.pl/_ftp/guar/Data/SFL/
- New protector used. Now client will start with antivirus sw.
I deleted ZIP with SFL2 files, now they are available as separated files. It will safe time to download only needed SFL2 files.
b.r.
Old 09-20-2007, 05:12   #29 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.69 Update Information
Ver 1.69
- PNX5230(Z310i) platform added. Simlock(CID49,51) and EROM UPDATE is NOT available for now.
Note: Change Band works also for Z310i models.
- Updated key combination message to enter BootMode for W880/W88x
- Updated key combination message to enter EROM Update mode.
For now I had only CID52 PNX5230 based phone(Z310i),I add CID51 loaders but they was not tested,hope will works. Because I had only CID52 phone so I can't add now simlock patch for CID49(yes they exists) and CID51.
All functions works as for DB2020 except Simlock/EROM Update. Band change works for Z310i phone too.
Because some phones can cause problems(wrong boot mode) while trying to update EROM I changed a bit key combination to enter EROM Update mode and BootMode. For be more clear and be sure for EROM Update first press and hold "5" key,after "2" key, hold them together and connect USB cable(this is only for USB).
Key combination message updated to enter BootMode for W880/W888 phones. There "C" key is used as power key,so for boot phone hold "2" key instead "C" key.
b.r.
Old 10-18-2007, 05:06   #30 (permalink)
Member: 384655
Thanks Meter: 517
Ver 1.70
- PNX5230 EROM CID51>CID52 bug Fixed.
- To protect download limits unathorized users can't download any flashes from support.
b.r.
REI Filter your SMS Version 2.00REI Filter your SMS Version 2.00 aapkae Nokia Multimedia 1 04-30-2009 16:08
L6 Bootcore Version 2.00 is not supported??? Panthereitor Smart-Clip 4 10-26-2007 15:29
New Nokia Winlock 4 Version 2.00.002 german gsm team Nokia Digital Core Technology 4 ( DCT-4 ) 0 11-12-2004 16:40
Smart Ericsson Tool version 2.00........... fixmobile Sony Ericsson 5 07-28-2003 09:41
Page generated in 0.26334 seconds with 10 queries
