Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > KULANKENDI Server
Old 10-22-2007, 16:47   #31 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.71 Update Information
Ver 1.71
- W580 model added
b.r.
Old 12-06-2007, 19:52   #32 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.72 Update Information
Ver 1.72
- W660 model added.
b.r.
Old 12-06-2007, 20:03   #33 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.73 Update Information
Ver 1.73
- Added CID52 Patch unlocking(only by USB cable).
- Fixed bug with selection Finalization + User Code (this will not work together).
Instuctions how to unlock CID52 by patch are available after mark/click Simlock CID52. This option can be marked ONLY when MAIN + FS files are loaded. Is possible to crossCID flashing so can be used ANY CID files(do not mix MAIN & FS CIDS. eg MAIN CID51, FS CID52). Also is possible to select additional options to be executed together with CID52 unlocking like Clear Call time,change CDA etc... but Clear Lock Code CAN'T be executed(loader limits) with CID52 unlocking together. CID52 patch unlocking require SFL2 file in SFL_Files directory what can be downloaded from http://rapidshare.com/files/74605479/Unlock_CID52.sfl2
Becasue all users for sure have USB cable I decide to make unlocking ONLY by USB coz is a lot FASTER (K790 ~ 9:45 min, W880 ~10.30 min).
Unlocking CID52 take 1 logs and free operation rules are same as before(3 free operation for same phone).
Finalization select IS NOT REQUIRED and disabled while do CID52 unlocking.
Before do CID52 charge battery good!!!
b.r.
Old 12-06-2007, 20:42   #34 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.74 Update Information
Ver 1.76
- Simlock and flashing support added for K530,S500,T650 phones.
Ver 1.75
- Grrrrrr - bugs...
Ver 1.74
- Some bug fixed
b.r.
Old 12-20-2007, 02:50   #35 (permalink)
Member: 384655
Thanks Meter: 517
Ver 1.77
- Christmas design .
- CID52 Unlocking procedure changed.Flashing after step 4 will do not erase bootloader code as first block so if any error will happen is possible to continue with new "B" option without repeat CID52 bypass procedure and pay log.
- New option named "B" for CID52 unlocking.After select MAIN + FS and mark CID52 unlock new option will appear at left.It allow to continue CID52 unlocking without repeat steps:1-4(it works only for already bypassed CID52 security)
- DB3150(A2) platform flashing/clear user code/reset call timers/change cda added.
WARNING: reset call time/change CDA works only with flashing!!!
About new "B" option. Some users report problem with flashing after step4,so they was presured to repeat all bypass operation. Now by mark "B" option(available after mark CID52) it will skip CID52 bypass procedure(4 steps) and continue final flashing.
DB3150(A2) platform please read short manual about flashing/using other options for A2 platform. Manual is available after switch to DB3150 page.
b.r.
Old 12-21-2007, 09:49   #36 (permalink)
Member: 384655
Thanks Meter: 517
Ver 1.78
- A2 Certificate length calculation corrected for CID0,49-53,80-109 Development flash files.
b.r.
Old 01-06-2008, 02:06   #37 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.79 Update Information
Ver 1.79
- A2 "Internal length" bug fixed.
b.r.
Old 01-06-2008, 02:13   #38 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.80 Update Information
Ver 1.80
- A2 block counting bug fixed what caused "File damaged" error for some files.
- W910i Flashing fixed.A2 flashing routines changed.
- Loaders updated for DB2020/PNX.
b.r.
Old 01-30-2008, 21:39   #39 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.81 Update Information
Ver 1.81
- PayPal instant account panel - no more waiting for Login/Pass after pay!!!
- Server<>Client communication protocol optimized.
- Some optimization for faster database management on server side.
!!! WARNING !!! DO NOT POST PayPal Information anywhere!!! Lost account(s) by user mistakes will not be refunded!
b.r.
Old 02-22-2008, 12:58   #40 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.82-1.83-1.84 Update Information
Ver 1.84
- Prepeare for Receipt ID verification process.
- Extended length for email in PayPal transactions.
Ver 1.83
- Download EXE link Fixed.
- Division by Zero bug fixed while unlocking more than 1 pc of phone.
Ver 1.82
- Fix autoupdate function caused changed ISP IP.
b.r.
Old 03-03-2008, 17:16   #41 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.85 Update Information
Ver 1.85
- PayPal ReceiptID supported for creating accounts.
b.r.
Old 03-14-2008, 16:33   #42 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.86-1.87 Update Information
Ver 1.87
- Support link changed.Old support page will not be updated anymore.
- Removed CID Phone<>File checking for A2 platform.
Ver 1.86
- EXE updated for new server with flash files.
b.r.
Old 03-19-2008, 14:02   #43 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.88 Update Information
Ver 1.88
- Language.ini file version detection fixed.
b.r.
Old 03-28-2008, 16:59   #44 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.89 Update Information
Ver 1.89
- New flash ID for phone A2 platform detection added 0xC9000401.
b.r.
Old 04-30-2008, 08:26   #45 (permalink)
Member: 384655
Thanks Meter: 517
Version 1.90 Update Information
Ver 1.90
- After user test, CID Phone<>File checking for A2 platform rolled back.
- Now possible longer CDA number for A2 platform.
- DB2020 CID53 support added.
b.r.
REI Filter your SMS Version 2.00REI Filter your SMS Version 2.00 aapkae Nokia Multimedia 1 04-30-2009 16:08
L6 Bootcore Version 2.00 is not supported??? Panthereitor Smart-Clip 4 10-26-2007 15:29
New Nokia Winlock 4 Version 2.00.002 german gsm team Nokia Digital Core Technology 4 ( DCT-4 ) 0 11-12-2004 16:40
Smart Ericsson Tool version 2.00........... fixmobile Sony Ericsson 5 07-28-2003 09:41
Page generated in 0.26148 seconds with 10 queries
