02-22-2008, 01:07 | #1 (permalink) |
Junior Member Join Date: Feb 2008
Member: 712940 Status: Offline Thanks Meter: 0 | Unlocking Huawei E220 for dummies (me) So before I buy via paypal please help: I have a Huawei E220 modem from Vodafone Spain (prepaid package) This (running with the VF-prepaidcard) is the only connetction to the internet. I now would like to use the Yoigo Prepaidcard. I reflashed my modem with following file from Huawei: E220-UTPSB002D03SP16C03 (Normal) (6870 KB) 14-Jan-2008 The Vodafone Card works. With the Yoigo Card it is possible to enter SIM number, which is accepted without a "wrong or no SIM message" But there is no Network (GRPS or HSDPA) found, trying to connect is followed by "You canīt connect before register an available network" Is this a problem because of an existing simlock or another problem. I do not have a problem to spent 15 Euro, but maybe it is not necessary ? If I have to unlock. Is this the requested Firmware or where do I get the right (for unlocking) one (please with link) I downloaded the Multiple Client. Can I see if the E220 is simlocked without buying the credits first? How shall I remove the card later (I have read that it is advised while unlocking) ? But I lose my internetconnection then (as there is no other way for me to go online), how shall I run the unlock then? I think it is done online via the server, or am I wrong? Thanks alot for your help !! |
02-22-2008, 11:43 | #2 (permalink) | |
No Life Poster Join Date: Nov 2006
Member: 384655 Status: Offline Thanks Meter: 517 | don't know what sw version U used, but it looks that U flashed application part in card. before buy download client from: http://gsminfo.home.pl/_ftp/guar/KK_...KK_MClient.exe and select PCMCIA modems and HUAWEI and click READ INFO and paste it here. I'll let U know what next and if is possible. b.r. Quote:
02-22-2008, 21:54 | #3 (permalink) |
Member: 712940 Status: Offline Thanks Meter: 0 | First I flashed the E220 with the Firmware the Client asks for. Re-installed E220, works fine with the original Vodafone card. Shows 7.2 Mbit max now. Downloaded multi-client. Read says: modem ports not available De-installed E220 and tried re-installing at all 4 USB ports . Same message. Device manager shows same results for all usb ports: Under "modem" (device manager) "Huawei Mobile Connect - 3G Modem" shows 7 tabs Under "modem" (tab) it says "Port: Com3" There is another entry in the device manager named "Ports (COM & LPT) now and within "Huawei Mobile Connect - 3G PC UI Interface (COM4) 5 tabs within and under "port settings" (tab) -- "advanced" it says COM port number : COM4 Tried the Yoigo Card again. It accepts the PIN but does not recieve a signal strengh wether GSM only or WCDMA only is checked. Anything I can do? I do not have any other Computer I can install the modem on (computer at work does not give me administrator rights). Kind regards |
02-25-2008, 12:37 | #5 (permalink) | |
Member: 384655 Status: Offline Thanks Meter: 517 | so all looks ok with ports Did U select HUAWEI in MC Client? Just select HUAWEI and click READ INFO b.r. Quote:
02-25-2008, 12:53 | #6 (permalink) |
Member: 712940 Status: Offline Thanks Meter: 0 | Hi, I have to retry it agin this evening after work. But I think I selected Huawei and then PCMCIA Card/Modem (or what it is called) Maybe that was the mistake... Will see later... |
03-04-2008, 23:52 | #9 (permalink) |
Junior Member Join Date: Mar 2008
Member: 718623 Status: Offline Thanks Meter: 0 | Good afternoon, I try to liberate it is not working and I get this error Why fix what? Looking for phone... Phone detected. Phone Model: Huawei E220 Firmware serie: E220 Phone IMEI: 35508301-274466-7 Serial number: No data. Firmware Version: 11.116.05.00.00 Simlock status: Enabled Connecting to server... Reading data... >> Firmware too old!Use newer from support << |
03-05-2008, 13:56 | #10 (permalink) | |
Member: 384655 Status: Offline Thanks Meter: 517 | did U flashed it with firmware from support? U have good firmware but maybe need to "refresh" it b.r. Quote:
03-05-2008, 14:56 | #12 (permalink) |
Member: 718623 Status: Offline Thanks Meter: 0 | I tested with another firmware, and does not work either Looking for phone... Phone detected. Phone Model: Huawei E220 Firmware serie: E220 Phone IMEI: 35508301-274466-7 Serial number: No data. Firmware Version: 11.116.05.00.18 Simlock status: Enabled Connecting to server... Reading data... >> Firmware too old!Use newer from support << |
03-08-2008, 22:59 | #14 (permalink) |
Member: 721608 Status: Offline Thanks Meter: 0 | Hi there everyone. Operating XPSP2, on a dualcore, 2.80GHz, 1000mg ram. I have a vodafone mobile connect modem Huawei E220, vodafone G3 Spain, using USB 2.0. The promised download speed is 3.6mg, but all I get is 15kb. One week ago for eight hours the download rate went up to 110kb, why I do not know and this speed has not returned; I am back to an average of 15kb. I understand that signal strength plays a great part in download, but the much higher download rate I experienced came at a time when the signal was rather poor. My question(s) is this, is the poor throughput due to some kind of restriction placed by Vodafone ? Or has it something to do with settings in the modem itself ? Or has it something to do with settings on my computer ? And if so what can I do about any of them ? Also I have recently download a firmware update for the E220 from http://www.vodacom.co.za/services/mo.../downloads.jsp. I have also downloaded VMC 9.3.1.0.8940.exe from the same site. Does anyone know if they will be ok to use for vodafone Spain ? Answers most apreciated and thanks for your time. Syr |
03-09-2008, 23:45 | #15 (permalink) |
Member: 712940 Status: Offline Thanks Meter: 0 | Now it worked ?! Looking for phone... Phone detected. Phone Model: Huawei E220 Firmware serie: E220 Phone IMEI: 35***701-***xx-1 Serial number: E07NAB17******x Firmware Version: 11.116.05.00.00 Simlock status: Enabled All Done! - Time:12:00:02 AM How do I go on? Thanks |
problen unlocking huawei e220 with kulankendi | cucaratxa | KULANKENDI Server | 3 | 08-31-2008 14:35 |
pleas help me i need unlock huawei e220 ? | SaMioC | KULANKENDI Server | 13 | 07-17-2008 02:07 |
Successfully Unlock Huawei E220 HSDPA USB Modem !!! | CNW | KULANKENDI Server | 10 | 05-16-2008 08:08 |
Successfully Unlock Huawei E220 with latest firmware | t6e6 | KULANKENDI Server | 0 | 01-22-2008 18:15 |
