12-19-2007, 15:21 | #1 (permalink) |
Junior Member Join Date: Dec 2007
Member: 657078 Status: Offline Thanks Meter: 0 | Vodafone Problems unlocking E 220 HSDPA USB modem unlocking to YOIGO. He got the name and password that I have sent, but these are the results: Select READ INFO Looking for phone... Phone detected. Phone Model: Huawei E220 Firmware serie: E220 Phone IMEI: 351*********** Serial number: No data. Firmware Version: 11.116.05.00.00 Simlock status: Disabled All Done! - Time:0:00:09 Select Execute Looking for phone... Phone detected. Phone Model: Huawei E220 Firmware serie: E220 Phone IMEI: 351*********** Serial number: No data. Firmware Version: 11.116.05.00.00 Simlock status: Disabled Error: Already unlocked - operation aborted. What can I do? With a password and user I got a log Where I put it? Thank you Jose |
12-19-2007, 22:12 | #2 (permalink) | |
No Life Poster Join Date: Nov 2006
Member: 384655 Status: Offline Thanks Meter: 517 | I reply U to UR PM just simple remove simcard from card b.r. Quote:
09-01-2008, 09:37 | #5 (permalink) |
Junior Member Join Date: Mar 2007
Member: 478062 Status: Offline Thanks Meter: 0 | Firmware flash problem Huawei E220 When I try to flash the firmware for the Huawei E220 I get this message: ANYONE KNOW WHAT THIS MEANS, I'm completely puzzled. WARNING Pay attention to the following during upgrade: 1: Make sure that the pc is running on full power (yes understand that) 2o not remove the data card . (what data card???) 3uring the upgrading process, the E220 needs to be unplugged and replugged once. Under Win2000, a dialog box will be displayed, saying "unsafe removal of device". This prompt does not affect the upgrading process . Under Win XP, the system will not prompt this. ( but if you unplug it the update is cancelled, so what do I do??? ) |
09-01-2008, 13:56 | #6 (permalink) | |
Member: 384655 Status: Offline Thanks Meter: 517 | point 2 mean that U can't disconnect E220 while flashing procedure, otherwise U will brick UR E220. point 3 - if u flashed it already then check firmware version if changed b.r. Quote:
The Following User Says Thank You to KulanKendi For This Useful Post: |
Amoi U2000+ HSDPA USB Modem unlock | melsoft | Various | 2 | 05-02-2010 14:12 |
Please unlock Huawei E1550 HSDPA USB 3G stick | vietnam123 | GSM Mobile Links | 3 | 03-26-2010 04:25 |
Amoi H01 HSDPA USB Modem | ataigun | Chinese Models & Cloned Phones | 0 | 04-02-2009 07:53 |
Vygis & ZTE MF626 [hsdpa usb modem] -Qualcomm | gulka | VygisToolbox | 0 | 02-15-2009 10:06 |
Successfully Unlock Huawei E220 HSDPA USB Modem !!! | CNW | KULANKENDI Server | 10 | 05-16-2008 08:08 |
