11-10-2007, 08:59 | #1 (permalink) |
Junior Member Join Date: Jul 2004 Location: Poland_Poznan_ Age: 39
Member: 73143 Status: Offline Thanks Meter: 2 | Z170 unlock problem I readed codes earlier, unfreeze it but i closed program by mistake and i didn't put unlock codes. Now i have still this message from server "No unlock codes available!". Phone has now 4 locks closed and doesn't support any card Phone info: ~~~~~~~~~~~ Phone Model: Z170 Revision: Z170PMGE4 IMEI: 354889010276234 SIM lock password: 0000 Connected to server Unlock codes: ------------- No unlock codes available! Disconnected from server BR Slaby6 |
11-11-2007, 12:20 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ALGERIA™ Age: 45
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | Z170 work well and tested today i think EUB team reset ur phone imei on samsung server from data base Phone info: ~~~~~~~~~~~ Phone Model: Z170 Revision: Z170BVGF1 IMEI: 354889012444889 SIM lock password: 0000 Connected to server Unlock codes: ------------- UNLOCK NETWORK LOCK: #7465625*638*06825953# Enter codes WITHOUT simcard inside the phone. You can check the current lock status using this code: *#7465625# Disconnected from server ************************************************** ***** Phone info: ~~~~~~~~~~~ Phone Model: Z170 Revision: Z170BVGF1 IMEI: 354889012444939 SIM lock password: 0000 Connected to server Unlock codes: ------------- UNLOCK NETWORK LOCK: #7465625*638*27403636# Enter codes WITHOUT simcard inside the phone. You can check the current lock status using this code: *#7465625# Disconnected from server |
11-11-2007, 12:51 | #3 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 43
Member: 55654 Status: Offline Thanks Meter: 9 | Quote:
Try to reset user code, or probably the flash is damaged Regards | |
11-12-2007, 15:40 | #4 (permalink) |
Member: 73143 Status: Offline Thanks Meter: 2 | Z170 problem I readed codes earlier, phone freezed, i put code to unfreeze it and by mistake i closed program Now when i put code *#7465625# only number 5 (SIM lock) is active, is there any way to read codes again? |
11-12-2007, 16:31 | #5 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Any Beautiful Place Age: 45
Member: 7900 Status: Offline Sonork: 100.78126 Thanks Meter: 4,991 | Please mail me to [email protected] your phone details IMEI and dongle details. Keep in touch, best regards !!! |
02-18-2008, 23:01 | #9 (permalink) |
Member: 55654 Status: Offline Thanks Meter: 9 | http://www.easy-unlocker.net/HowToUnlock/Samsung_Z170/ If the phone is freeze, will be show the unfreeze code. Regards! |
Z170 unlock problem | midomachakil | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 08-09-2009 17:45 |
z170 unlock problem! | neo25_gsm | UST Pro II | 1 | 12-23-2008 17:01 |
z170 unlocking problem... | SicilianBoy | UST Pro II | 11 | 07-16-2008 18:51 |
Z170 unlock problem pls help | unitedtelecom | Easy-Unlocker | 3 | 05-27-2008 15:39 |
z170 unlock problem :/ | Bodzio | KULANKENDI Server | 2 | 03-31-2008 09:23 |
