07-09-2009, 14:22 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: canada
Member: 404967 Status: Offline Thanks Meter: 33 | can't unlock f480 with eubox ~~~~~~~~~~~ Phone Model: F480 Revision: F480AGIC1 IMEI: 3549260****** Reading data from phone... ERROR - Unsupported simlock algo! |
The Following User Says Thank You to walidprestige For This Useful Post: |
07-09-2009, 14:38 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | post screen shot, to see better what happens f480 supported well with eu box consult howtounlock section and check if u r doing everything well or post screen shot BR, |
The Following User Says Thank You to boucettay For This Useful Post: |
07-10-2009, 09:26 | #3 (permalink) |
Major Poster Join Date: Aug 2006
Member: 322986 Status: Offline Thanks Meter: 17 | F480AGIC1 : Not pass Flash it with firmware : F480ADHG1 pass it with eubox : Ok Revision: F480ADHG1 IMEI: 35XXXXXXXX88282 SIM lock password: 0000 Connected to server Unlock codes: ------------- UNLOCK NETWORK LOCK: #7465625*638*18696028# Enter codes WITHOUT simcard inside the phone. You can check the current lock status using this code: *#7465625# Disconnected from server |
07-10-2009, 09:43 | #4 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Turkey
Member: 337837 Status: Offline Thanks Meter: 538 | Phone info: ~~~~~~~~~~~ Phone Model: F480 Revision: F480ABHI1 IMEI: 35************* SIM lock password: 0000 Connected to server Unlock codes: ------------- UNLOCK NETWORK LOCK: #7465625*638*03507503# Enter codes WITHOUT simcard inside the phone. You can check the current lock status using this code: *#7465625# |
The Following User Says Thank You to sairat For This Useful Post: |
09-02-2009, 18:50 | #11 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 742967 Status: Offline Thanks Meter: 18 | to JAVVAD : I don't think flashing the phone is a solution. Where are eubox standards? "read code = save phone warranty". As far as we have to flash phones, we meet several problems : 1/ the customer loses his data 2/ the phone has no more warranty 3/ the operation is risky 4/ we use a none eubox solution to flash Don't forget your devise : We HARDLY RECOMMEND TO USE READ CODES DUE TO USING THIS OPTION YOU´LL NEVER DAMAGE ANY PHONE as you´ll suffer using other TOOLS which DAMAGE IMEI even changing it using others tool´s Direct Unlock. EASY UNLOCKER BOX IS SAFEST WAY TO UNLOCK PHONES !!! that's why we bought eubox. Besides, this is not the first we ask complain because of the same version of F480 (AGIC1). take it well. |
09-02-2009, 22:02 | #12 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: Any Beautiful Place Age: 45
Member: 7900 Status: Offline Sonork: 100.78126 Thanks Meter: 4,991 | Quote:
Take it well Best Regards !! - aErOm - | |
The Following User Says Thank You to aErOm For This Useful Post: |
09-05-2009, 03:57 | #13 (permalink) |
No Life Poster Join Date: Apr 2004 Location: ORAN-ALGERIE Age: 49
Member: 64213 Status: Offline Thanks Meter: 493 | solution all freezing samsung f480 - f490... more with easy to clic sos call & tape code unfreezing with "#" enjoy ask u for network lock tested by me |
A177 unlock procedure with EUBox?? | Unlocker AL | Easy-Unlocker | 2 | 10-14-2009 18:02 |
How to unlock B320 with eubox? | sjakie | Easy-Unlocker | 9 | 02-05-2009 10:01 |
KU990 Unlocked successfully with EUBOX | gsmfriend | Easy-Unlocker | 3 | 12-03-2008 22:09 |
Anyone tried unlock L810v with EUbox? | korter | Easy-Unlocker | 5 | 10-17-2008 09:16 |
how to unlock f480 with securité code | cybermphone | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 4 | 09-01-2008 15:30 |
