»» F480v Perfect solution to unfreeze phones «« hi to all you will need
After flash Boot Loader, Flash the Phone, them phone start up ( Non Acepted card ) the choice call, enter freeze code and wait some 3 to 5 seconds. phone will ask for Net Code ( NCK ) enter the code and voila, phone its unlocked. Tested by me, it works. B.r. guedes666 |
can u tell me which version u flash ,bcos i flashed it in F480XEHE1 ver ,after try to enter unfreeze code but no result |
the version that i use is F480XXHF7 B.r. guedes666 |
yes solution work perfect i have tested & work fine flash phoe & unlock with easy unlocker 2.54 entre phone frez & entre cod network ;) |
@guedes666 thanks for help there and share info. with all users !!! |
always working to the good of comunity gsm b.r. guedes666 |
yes it is really work ,thanks |
it's easy use Samsung 3G online code reader (some F480 version can't be unlocked with direct unlock even after full flash, boot, reset etc...). u will get unlock code and unfreeze code, the F480 have a little difference from F490, because u can use the unfreeze code not like the other one. Method to Unfreeze F480(V): - Use Samsung 3G Online Code Reader, u will get Unlock and Unfreeze code, - Put a non accepted SIM Card and power On the phone, - U will get on screen "Phone Freeze etc..." and 2 Screen Key (SOS and CALL). - Press the "Call" Screen Key, enter UNFREEZE CODE and in the Second u Will get "Network Lock" (other code will not do anything). - Tape ur Network Unlock code - That's all. this solution for bourri gsm.. http://forum.gsmhosting.com/vbb/show...+freeze&page=2 |
flashing phone may cause problems with some cases, i thing EU have to developpe its application to handle all version by 1 direct unlock solution thx |
for unfreeze any 3g use phone with any not supported sim card and press start in 3g easyunlocker |
Solution already found by me there http://forum.gsmhosting.com/vbb/show...3&postcount=22 and http://forum.gsmhosting.com/vbb/showthread.php?t=637232 by the way: 1- it's really usefull for F480V Freezing and can't be unlocked by direct unlock method. 2- Flash of boot file isn't needed at all (do not risk with boot files of flash file from unknown source) 3- i think isn't by luck u have used this firmware version F480XXHF7 :D because u will not be able to unfreeze phone with other F480(V) existing firmware :D. someone say it's tested a long time ago (like found since 1 years ago when those version not released yet :D), but i don't think. many peoples here asking for solution but he don't help, just bla bla when someone find something hahaha. br:) |
thanks BouRRi_GSM for help there !!! |
