12-17-2007, 11:31 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Any Beautiful Place Age: 45
Member: 7900 Status: Offline Sonork: 100.78126 Thanks Meter: 4,991 | Well this model has not checked by us already, if you want, you can try by reading codes, the much you can get is CODES or Wrong result but you´ll never damage phone by reading so... LET´s TRY IT !!! and post results. Best Regards !! |
01-10-2008, 04:58 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Location: In Your Room Age: 47
Member: 97299 Status: Offline Thanks Meter: 43 | here some info Phone info: ~~~~~~~~~~~ Phone Model: F700 Revision: F700AMGJ8 IMEI: 358444010****** Reading data from phone... ERROR - Can't get CRYPTKEY! p.s. have used combo e210 l760 self made cable hope this is the problem |
01-10-2008, 10:48 | #5 (permalink) |
Member: 7900 Status: Offline Sonork: 100.78126 Thanks Meter: 4,991 | Please POST SCREEN SHOT, may be you have something wrong in your selection, by posting SCREENSHOT we could help you otherway impossible. Regards !! |
01-10-2008, 12:51 | #7 (permalink) |
Member: 7900 Status: Offline Sonork: 100.78126 Thanks Meter: 4,991 | Please select as ZV60 and use correct ports, also check that your modem is not installed in a port upper than #19 Try and post results please. Best regards !! |
01-10-2008, 13:07 | #8 (permalink) |
Member: 97299 Status: Offline Thanks Meter: 43 | there is no modem found even with original usb cable will not found a modem just if i start the phone in download mode and use original usb cable |
01-10-2008, 18:50 | #9 (permalink) |
Member: 7900 Status: Offline Sonork: 100.78126 Thanks Meter: 4,991 | Man you have not USE the USB ORIGINAL CABLE but the USB+RJ45 Combo CABLE for V809 YES, so use this cable and post results !! Regards !! |
01-11-2008, 13:47 | #13 (permalink) |
Member: 7900 Status: Offline Sonork: 100.78126 Thanks Meter: 4,991 | Douhal I´m looking up your problem, it´s different you know... Don´t press me PLZ. Thanks for comprenhension and Best regards !! |
how to unlock 5800/N96 with Mx key? is it possible or not? | malikzahidawan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 08-08-2009 21:12 |
Z240.some Version Not Suported Or How To Unlocked It? | mamepap | PolarBox 3 | 2 | 08-28-2008 13:05 |
cid53 unlock, is it possible or not?! | milanplazina | Sony Ericsson | 16 | 05-15-2008 19:03 |
T68.to.W810i is it possible or not / how !? | serseg.gsm | Sony Ericsson Hardware Repair | 1 | 11-14-2007 10:12 |
mail from gsmunlock with virus is it real or not? | leosedf | Off Topic Zone | 7 | 01-24-2005 12:22 |
