How to reset security code on F490 ? HI, I have an F490 with security code. So I can t connect it with sasmsung cdma model. How can I reset security code ? Don t say me *2767*2878 .... cause I can t do any code cause no keypad. If you did already one please help, or if not nothing. THks |
try with 00000000, try to flash firmware, i have not idea at this time how to do |
search the forum already posted and it works,i have tested |
anyway the easy method for all to unlock Samsung F490 phone freeze, use "Samsung 3G Easy Unlocker" not online one connect combo cable to phone - set port1 for Samsung CDMA Modem and Port2 for COM port - power off the phone, then power it on - when phone start power on, it will be directly detected by ur PC, and before it show "phone freeze" click "START" button - phone unlocked i mean the trick is to unlock phone when it start power on and detected; and before it show "phone freeze" message in the screen thanks to BouRRi GSM good luck alexmkdmafia |
@alexmkdMAFIA 1st read post care fully then do answer, NO NEED to COPY PASTE Q. is how to reset user code (no network code) |
And when I put in my post "If you did already one please help, or if not nothing ", it s because too many people talk for nothing (as you) and after we have post with 50 pages for NOTHING. PLEASE READ AND RESPECT POST |
1 Attachment(s) F490 Multi Loader Version: v5.33 DOWNLOAD NOW F490 Firmware (flash File) DOWNLOAD NOW Instructions: How to Boot DOWNLOAD MODE F490 ?*Boot the F490 by pressing 'power ON' + 'Camera hot key' + 'Volume Up Key' at the same time. If you do properly, you can see the following message on Main LCD "Download" http://forum./atta...1&d=1211798858 Speacail thanks "allal123" |
I thik that security code could be restored to "00000000" by entring this code: *2767*3855# I trued in various samsung models. |
*2767*3855# this code work grate tested by me |
so please wait for his reply, i think he have solve his problem |
after flash Rsc1 rebuiled error , i did flash with Rsc1, Rsc2 and factory fs |
rebuiled Rsc1 but same condition |
Contact me for help, because full flash can't be possible if security code is ON, you ll get message box error, so there is an other way to avoid this pb, tested both on f480 et f490, 200 secondes only ;) B.R .:Kimo59:. |
